P 0740 transmission code - JeepForum.com
post #1 of 3 Old 12-20-2013, 12:16 PM Thread Starter
justn
Wj P 0740 transmission code
Just the other day on the highway my jeep decided to turn on the check engine light.
Checked the odometer code, got a p 0700, so I took it to get the codes read and discovered its a p 0740 which is a torque converter lockup malfunction code. The ODB II meter also said it was an open circuit.
I have no huge symptoms other than the transmission not shifting all the way into overdrive sometimes, or taking a long time to shift into overdrive.
Transmission fluid level is good, and it doesn't smell burnt.
What are some easy things to check first?
My Build Thread for the old WJ
http://www.jeepforum.com/forum/f197/justns-build-thread-1236882/
justn is offline
post #2 of 3 Old 12-22-2013, 08:36 PM
link375
check the transmission relay and make sure it works properly
link375 is offline
post #3 of 3 Old 12-23-2013, 09:01 AM
Double E
Double E's Avatar
Test your input sensors: http://www.jeepforum.com/forum/f13/s...ailure-561977/
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
