Overland Suspension Kit (lower the car) - JeepForum.com
post #1 of 20 Old 04-16-2013, 09:42 AM Thread Starter
heartcold82
2003 WJ
Wj Overland Suspension Kit (lower the car)
Hello,
I have just bought a second hand overland 2003.
when first saw it i was chocked by the height of the car. bareley higher than a normal car. It look very sporty, but the car is low. Seller told it is a special suspension kit to have more gas mileage (fuel economy) (13l/100km) and better handling.
Now that i have bought the car, i need to recognise what suspention kit the car have in order to study the suspension kit risk etc....
Is it possible to recognize somin from the pic? O dear pros ?
of not, plz help me !
heartcold82 is offline
post #2 of 20 Old 04-16-2013, 09:48 AM
WhiteOut
WhiteOut's Avatar
Maybe show us some pictures of the suspension. Right now we can tell you its a Jeep and has headlights. It is also silver in color.
WhiteOut is offline
post #3 of 20 Old 04-16-2013, 09:54 AM
Thomahawk
Hub fender messurments would give us a good idea, if its lowered, lifted, or stock height.
What shocks do you got?
Sway bars might been upgraded as well for better handling.
Buildthread
Thomahawk is offline
post #4 of 20 Old 04-16-2013, 10:31 AM
lvngtheJEEPlife
And dont forget the GOD AWFUL chrome mirrors. Please just end that things misery
2001 WJ Limited 4.7 Powertech, Quadradrive, 2" BDS lift.
"If you can't get there in a Jeep, You should reconsider going there."
lvngtheJEEPlife is offline
post #5 of 20 Old 04-16-2013, 10:39 AM
jeep04
I know it doesn't answer your question but looks like the grill was changed to one from an 04, i thought the 03 overlands just had the chrome trim pieces. As well added those chrome plastic mirror covers and door handle covers which ruin whats under there if you ever take them off as i found that out.
04 Jeep wj Limited 4.7 <> 6.5" Iron Rock long arms front & Adjustable lowers on rear <> Bilstein 5100's <> 285/70r17 Goodyear Duratracs <> M/T black classic lock wheels <> Addco swaybars <> Superchips 3875 <> Magnaflow Stainless exhaust <> 2 Kicker comp 12's <> Kenwood head unit.
jeep04 is offline
post #6 of 20 Old 04-16-2013, 11:06 AM
its-me-B
Just from that view it looks like it's lowered 1.5 inches... I always back in and when I was stock my front end was higher than that. Get inside it and turn the wheel all the way to one side and have a look at the springs. Most aftermarket springs will be colored, blue,red,yellow,ect...
Do the world a favor, hurt a honda...
Iro 3" lift with pro comp 9000es shocks, adjustable trackbar, led rock lights, all interior lights converted to leds, two 10" kicker comp with Kenwood 600 watt amp
Zombie Outbreak Response Unit #396
its-me-B is offline
post #7 of 20 Old 04-16-2013, 11:22 AM
ZB_WJ
Probably has a Eibach lowering kit with springs and sway bars. Looks like PO has done quite a few mods already!
I think we all just need a beer. :cheers2: (courtesy of ChrisHager)
This forum is a double edge blade, it's saved me thousands in repairs and cost me thousands in mods
ZB_WJ is offline
post #8 of 20 Old 05-04-2013, 11:16 AM Thread Starter
heartcold82
2003 WJ
Well i could finally grab some pics
post #9 of 20 Old 05-04-2013, 11:17 AM Thread Starter
heartcold82
2003 WJ
So any idea what kit itis????
Thx guys
post #10 of 20 Old 05-04-2013, 11:26 AM
jeep04
Something don't look right with those springs, its definitely not an Eibach lowering kit as I had that for grand cherokee and the springs did not look like that.
Does it ride OK?
jeep04 is offline
post #11 of 20 Old 05-04-2013, 11:31 AM
DavisI
I could be wrong here, but it almost looks like some of the coils are welded together
2002 WJ 4.7
4.5"/3.5" with 32"x10"
DavisI is offline
post #12 of 20 Old 05-04-2013, 11:48 AM
EisBlade
EisBlade's Avatar
Still doesn't add up. The tighter portion of coils still have even spacing. If a couple were welded they wouldn't...unless there are metal spacers welded in we can't see. OP, do you see anything?
What about alternative vehicles whose springs would fit, and the PO using a lowering/custom set from there?
These are Eibach lowering springs.
These are H&R lowering springs. Either one are black and would wind tighter on one end with some spacing.
JT
Facebook: Harley-Davidson Touring Group
EisBlade is offline
post #13 of 20 Old 05-04-2013, 11:58 AM
ZB_WJ
Those h and r springs look like they match what was posted
ZB_WJ is offline
post #14 of 20 Old 05-04-2013, 12:27 PM
jeep04
Or someone did it cheaply and heated up the factory springs ....even on those h&r springs the coils wouldn't be touching
jeep04 is offline
post #15 of 20 Old 05-04-2013, 01:18 PM
Kolak
Vendor
Kolak's Avatar
You have progressive rate lowering springs and they're either Eibach or H&R.
The appearance of the coils touching is normal for this type of spring. They call that a "dead coil" when they're touching at ride height. You're compressing the higher rate coils upon initial compression, but when they rebound you'll get a softer rebound and initial compression as the dead coils expand and compress.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is online now
