Overland rock rails - JeepForum.com
post #1 of 11 Old 02-27-2013, 07:16 PM Thread Starter
fosterjd79
Overland rock rails
I am debating buying aftermarket rails but I have Overland rails already installed. How much can these handle? I saw a thread about beefing them up by pounding in galvenized pipe but is this necessary?
fosterjd79 is offline
post #2 of 11 Old 02-27-2013, 08:09 PM
Indslpwr04
Considering as much as they weight they should handle a decent amount. I took mine off because they were rusted out. Zipped all the bolts out with the air gun and it fell and almost took my head off. I'd say they weigh 40-50 lbs a piece.
2002 Overland. All stock, for now.
Indslpwr04 is offline
post #3 of 11 Old 02-27-2013, 08:13 PM Thread Starter
fosterjd79
Can I throw a farm jack under it and jack up both wheels without it caving in?
post #4 of 11 Old 02-27-2013, 08:13 PM
thisguyhasadd2
they are hollow and usually rust out from the end caps. the steel is only 1/8 - 3/16 thick.
2002 Overland - 4" rc -255/75/17/Jk Moabs
1982 Yamaha XT200J- dead, rebuild winter
Colorado Jeep Club Member#259
thisguyhasadd2 is offline
post #5 of 11 Old 02-27-2013, 08:25 PM
funkduck
2015 KL Cherokee
I don't know what this "rust" stuff is you guys are always going on about, but out here in Arizona the stock rock rails are real deal, you can actually use them. They don't stick out very far so they won't protect doors as well as some other rails, but you can lift the vehicle from them and they'll take very little damage being scraped across rocks.
funkduck is offline
post #6 of 11 Old 02-27-2013, 08:29 PM Thread Starter
fosterjd79
1/8" is a .125 wall and 3/16" is a .188 wall. The JCR sliders are a .188 wall so they aren't much stronger if they are at all. Is there another brand of slider that is stronger other than DIY?
post #7 of 11 Old 02-27-2013, 11:39 PM
USFORCES
They are around 1/4" plus they have extra steel welded to them, if you live in a salty state like me it's a good idea to rust proof them on the inside. I can pretty much bet if the rock rails are rusted through so is the rest of the jeep, lol
04 Overland on 33's, Lift & tires= 8" over stock.
USFORCES is offline
post #8 of 11 Old 02-28-2013, 07:17 AM
soupy688
Yep same rust issues here in Pennsylvania. But I rust proofed my sliders before the got bad. The rock rails are pretty stout at do take some abuse and like stated above you can hi lift off of them with no problems.
2012 Jeep JKU Call of duty MW3 serial # 1526/3500 Bone Stock
soupy688 is offline
post #9 of 11 Old 03-02-2013, 10:45 AM
USFORCES
If you lift your jeep using the overland rock rails make sure all the bolts are still nice and snug, seem's to me I had a missing rock rail bolt on mine when I first got it...
USFORCES is offline
post #10 of 11 Old 03-02-2013, 05:13 PM Thread Starter
fosterjd79
Cool, thanks for the heads up.
post #11 of 11 Old 03-08-2013, 06:11 PM
CLUBSFIT
2003 WJ
If anyone has Overland rock rails they want to sell, shoot me a PM, I will handle shipping also.
thanks
03 limited 4.7 H.0., Superchips, TM wire snip mod, K&N drop in with custom intake box. 265/70/17 TKO's
BDS 4" coils, KOR .75 rear spacers, Fox shocks, BDS adj LCA's, A-arm spacer, adj.track bar, quick disc. front links, extended rear links, dual SS, Addco rear sway bar.
CLUBSFIT is offline
