Out of time ? - Page 2 - JeepForum.com
 1Likes
post #16 of 28 Old 06-07-2017, 12:43 PM
sdg3205
I don't think the tensioners use oil pressure. They're just spring loaded, but I've seen chains that were so worn that the tensioners were ratchet all the way out and not doing much in the way of adding tension.
sdg3205 is offline
post #17 of 28 Old 06-07-2017, 02:15 PM Thread Starter
maggiemay
Im gonna start with the head first to get it running just to see or hear if the main or rod bearings are damaged. If I have to pull the engine to replace the bearings or grind the crank or whatever, then I look forward to it.
I always thought the chain tensioners used oil pressure since when you collapse them in a vise, oil squirts out of them. I could be wrong... again.
maggiemay is offline
post #18 of 28 Old 06-08-2017, 08:54 AM
dokonewski
Do yourself a favor and check your bearings ... I say this because my timing system and heads looked brand new. Bearings? Not so much ...
Timing System:
Drivers Side Head:
#5 Main Bearing
Rod Journal:
dokonewski is offline
post #19 of 28 Old 06-11-2017, 04:32 PM Thread Starter
maggiemay
I pulled the engine and checked the main and rod bearings. They still look brand new. I replaced the bent valves. Got the engine back together. Rotated the engine about 8 times. No binding or anything. Will start putting the engine back in tomorrow. Will take me a couple days.I'll report back when i get the jeep started .
wadewen likes this.
post #20 of 28 Old 06-11-2017, 05:21 PM
WJChris
WJChris's Avatar
good to hear, thanks for the update!
WJChris is offline
post #21 of 28 Old 06-12-2017, 07:18 AM
Numb-Nutz
Whilst your there, change the oil pump and don't cheap out spend the extra $30 and go genuine.
Sent from my Pixel using Tapatalk
Numb-Nutz is offline
post #22 of 28 Old 06-13-2017, 11:56 AM
dokonewski
Thank yourself in a few months that you checked the bearings. The peace of mind it will buy you is priceless.
post #23 of 28 Old 06-16-2017, 05:13 PM Thread Starter
maggiemay
Got the jeep running today. Sounds really good. Have a few things to button up before I take her for a drive.
post #24 of 28 Old 06-16-2017, 05:24 PM
wadewen
His: 97 TJ Sport -
FSM Link:
Hers: 02 WJ Overland -
FSM Link (have to create login) -
wadewen is offline
post #25 of 28 Old 06-17-2017, 03:28 AM
mak_v8
Grand Cherokee WJ 4.7 V8 HO. m.y. 2002
mak_v8 is offline
post #26 of 28 Old 06-17-2017, 05:11 AM
HarryH3
Awesome news! Now go have fun with it.
HarryH3 is offline
post #27 of 28 Old 06-17-2017, 08:24 PM Thread Starter
maggiemay
The jeep drives like brand new.
$900 for the jeep. $400 in parts.
The joy I had tonight driving the jeep,.. priceless...
post #28 of 28 Old 06-19-2017, 11:35 AM
dokonewski
Always like to hear a success story. Especially done on the cheap
