Opinions Needed On Front Driveshaft - Page 2 - JeepForum.com
post #16 of 17 Old 03-28-2012, 01:03 PM
AGDubyaJ
^ take the driveshaft out and see if the noise goes away. if it goes away... its your driveshaft.
98 XJ- 4.0L, NP231, AW4, chryco 8.25, 4.5" mid arm 3-link, 285/75 Herc terra tracs on moabs, V8 ZJ tie rod, fabbed bumpers...
AGDubyaJ is offline
post #17 of 17 Old 03-28-2012, 05:02 PM Thread Starter
MWF
Well after asking around various parts suppliers in the UK nobody is prepared to supply a new joint for less than 100 ($160).
Also reading around it seems export WJs did get the double cardan upgrade, I can't find any driveshafts that aren't rezeppa-rezeppa.
Plus reading through lots of posts on the subject there's little conclusion if it's the lift that's the issue or the reverse boot setup just being vulnerable to contamination and abuse.
So given that I do low miles in mine, mainly on road and only with a 2" lift I'm going to see about importing one of these cheap joint kits from the US, fitting that and seeing how long it lasts.
Took the old cv off today, even with the clip off it took some pounding to get it off the shaft.
MWF is offline
Opinions Needed ASAP(Front Driveshaft vibe) Chris00WJ WJ Grand Cherokee Forum 23 09-20-2012 01:42 PM
Opinions needed please RebelX WJ Grand Cherokee Forum 22 04-03-2012 08:53 PM
WJ Build list - opinions needed MiCrOz WJ Grand Cherokee Forum 8 12-26-2011 12:08 AM
Question for all WJ owners opinions needed BostonBull WJ Grand Cherokee Forum 6 10-29-2003 06:47 PM
