Opinions on going from 30.5" to 32" tires on IRO 3" lift - Page 3 - JeepForum.com
 6Likes
post #31 of 53 Old 05-10-2013, 09:12 PM
bmandubj10
2003 WJ
Thank you guys for this thread, I was having the same issues with the rear chewing up my tires on the trail. I have the IRO 3 inch coil lift with General Grabbers 265/70R17 (32s) and saw the bump stomp extenders and was researching them. The guys that have them are you running the 3 inch extenders I was going to go with them so my wheels do not rub on the trail anymore? I also already have all new four lower isolators and some OME 10mm spacers from Kolak waiting to be installed as well for my setup.
Here is a link to the pictures of my setup my jeep is the white one with all the pictures on this page. I cannot upload my pictures they are too big I guess the changed some settings on the site:
http://www.jeepforum.com/forum/f310/...95/index4.html
- 2003 WJ Limited 4.7L 4x4, 3 inch IRO coil lift with Bilstein shocks, OME .5 inch spacers, adjustable IRO Track Bar. Beefy Tenneco Steering Stabilizer. 32 inch General Grabber AT2's, 5000k DDM Tuning HID lights. Magna Flow Cat-back exhaust system. Rola safari rack. IRO bump stops. Kevin's Offroad 2 1/4 A-Arm spacer.
bmandubj10 is offline
post #32 of 53 Old 05-12-2013, 06:32 PM
bmandubj10
2003 WJ
just ordered the 3 inch bump stop extenders from IRO cannot wait to get them!!!!
post #33 of 53 Old 05-12-2013, 07:02 PM
fast540
With all these bumpstop extensions won't u limit flex to less than stock ?
fast540 is offline
post #34 of 53 Old 05-12-2013, 07:29 PM
bmandubj10
2003 WJ
Correct but I only do light wheeling and some rock but nothing big. I just want to prevent my tires from getting chewed up in my fenders especially in the rear.
post #35 of 53 Old 05-12-2013, 08:23 PM
fast540
Gotcha. I rub lightly off road on 32" tires and 4.75" lift with the fr bumper cut way up and a protofab r bumper but we go pretty hard disco'd that's y I asked
fast540 is offline
post #36 of 53 Old 05-12-2013, 08:32 PM
bmandubj10
2003 WJ
Yea man I have yet to run disconnected I was afraid too.
post #37 of 53 Old 06-17-2013, 10:15 PM
RIPNBST
Good grief. I'm on an IRO 3" lift and am headed out wheeling this weekend and haven't trimmed or bump stopped anything. On 32" tires as well.
Sounds like I will see what all I need to modify pretty quickly.
RIPNBST is offline
post #38 of 53 Old 06-17-2013, 11:01 PM
MuddyWJ
Take off your front bumper and youll be fine. Light rubbing in rear but that's fixable. Just went wheeling last weekend and forgot to take mine off........ I'm now in need of a new bumper. Oh well upgrade time. 3" bumpstops that's crazy! I measured at close to 4" of lift and only got 2" bumpstops.
MuddyWJ is offline
post #39 of 53 Old 06-18-2013, 08:54 AM
RIPNBST
Front bumper will be coming off then. Thanks for your advice Muddy.
RIPNBST is offline
post #40 of 53 Old 06-22-2013, 11:20 PM
Dan_d
I see everyone has 16" rims, I just installed the 3" IRO Lift too but I have the 17" factory rogues and was wondering what size tire I should get for them. Right now I just have 235/70/17.
Dan_d is offline
post #41 of 53 Old 06-22-2013, 11:32 PM
WeThePeople408
Originally Posted by dan_d View Post
i see everyone has 16" rims, i just installed the 3" iro lift too but i have the 17" factory rogues and was wondering what size tire i should get for them. Right now i just have 235/70/17.
265 70 17
WeThePeople408 is offline
post #42 of 53 Old 06-23-2013, 04:31 AM
ADragg
2003 WJ
Are you sure your bumpstops even work at only 2" extension? How much are your tires???
ADragg is offline
post #43 of 53 Old 06-23-2013, 10:40 AM
fast540
My stock bumpstops work at 4.75" lift and I get no real rub on 32" tires
fast540 is offline
post #44 of 53 Old 06-24-2013, 01:28 AM Thread Starter
gtg413i
2003 WJ
Are you running with disconnected front sway bars?
Brian's Black Betty Build:
gtg413i is offline
post #45 of 53 Old 06-25-2013, 10:24 AM
RIPNBST
Wanted to add my experiences here if I may.
Went wheeling for the first time this weekend since my 3" IRO lift. Rubbed pretty badly in the rear but not horrible (not bad enough to break something) and had a front spring come unseated on the trail...not cool but caught in time it wasn't a huge deal. Backed down slowly and had a buddy pop it back into place before backing all the way down the obstacle.
With front bumper removed(painless and WELL WORTH IT to save your front bumper + additional approach angle) I did not rub anything in the front at all. My plastic fender liners are completely removed front and rear and my windshield washer fluid reservoir has been removed as well. Getting this out was more of a PITA than anything else really.
If you are gonna wheel like you've got a pair while disco'ed then I recommend installing spring retainers be added to your build sheet as well. I didn't plan to go disco'd that day but when I lost an endlink bolt I really had no choice but to disco both sides.
As a result of this past weekend of learning experiences I now decided I need...JKS QD's, rear bumpstop extensions(1.5" maybe? Running 265/70/17 tire), and front upper and lower spring retainers.
In this pic the spring is unseated though tough to see, I was further up the rock face when it popped out. Pic was taken after I had backed down some.
You can hear the rear rubbing in this video but the quality is horrible. I will run this again and shoot it with a real camera. And oh yeah, be prepared to crane your head 90 degrees to watch it haha.
http://s143.photobucket.com/user/ras...4a8e7.mp4.html
maxfederle89 likes this.
RIPNBST is offline
So im at 3" now and planning to go 4" to tack in the 32" duratracs w/ 16" steelies. blazepsi WJ Grand Cherokee Forum 2 10-24-2011 04:19 PM
How much to trim with 4" lift 33" tires? YZ212 WJ Grand Cherokee Forum 10 08-26-2011 12:39 PM
"Jeep", "Grand Cherokee", "4x4" and "V8" font question... Radosl81 WJ Grand Cherokee Forum 7 02-23-2011 04:37 PM
2" lift opinions kastner03 WJ Grand Cherokee Forum 9 12-29-2010 09:39 PM
pic of my laredo with 2" BB --31" tires and 15" rims MANUBI WJ Grand Cherokee Forum 9 08-26-2010 07:34 PM
