Opinions on going from 30.5" to 32" tires on IRO 3" lift - JeepForum.com
post #1 of 51 Old 01-18-2012, 12:08 PM Thread Starter
gtg413i
2003 WJ
Thought I'd add some pics of what 30.5" tires look like disconnected with bump stops on 3" lift and get opinions on 32" tires. I installed a 3" IRO lift on my 03 overland. I installed 265.65/17 tires (30.5") with JK wheels (max diamater tire that would match a spare and still fit in the spare part). After taking the jeep to a an offroad park trail head, my tires looked pretty weak so looks like I need more meat. Below are pics of the front tire at full uptravel and hitting the bump stop extension with front dissconnected.From everything I see, it looks like I would have had to trim if not for the bump stop. So, today I bought a set of rubicon tires BFG KM2 (255/75/17 - 32.1" new, but they have 70% tread left $385 for 4). I plan to use this second set for offroading trips only and remove my front bumper for offroading), and strap the spare in the cargo area. With the bumpstops (front and rear) and not running my front bumper cover, and disconnected I'm hoping to avoid too much if any trimming, but might have to do washer bottle relocate and add wheel spacers. Anyone with that tire size on 3" lift want to chime in how much was needed to trim for wheeling disconnected? Also, how much of a PITA is it to have to switch tires and remove the bumper for offroad trips?
Brian's Black Betty Build:
gtg413i is offline
post #2 of 51 Old 01-18-2012, 01:57 PM
alwaysHI
2003 WJ
I'm running 265/75/16 (31.8 roughly a 32) on IRO 3" on stock silverblade #1. I had to extend my bumpstop 3" in order for me to turn lock to lock, while disco'd, and not eat my fender or washer bottle.
Bronson = 21 yrs. old
BUILT, NOT BOUGHT - WORKED HARD FOR, NOT KISSED MOMMY/DADDYS A** FOR!
Build Thread -
SOLD
alwaysHI is offline
post #3 of 51 Old 01-18-2012, 03:12 PM Thread Starter
gtg413i
2003 WJ
I think that's what I got for bumpstop extension link and should have about 31.8 diamater as the tires are worn. It looks like you don't have to remove the front bumper to wheel, did you have to trim front and rear? Funny enough, I'll be passing through Hilo on Sunday going to the volcano park for vacation. Will look out for your wj.
gtg413i is offline
post #4 of 51 Old 01-18-2012, 03:27 PM
alwaysHI
2003 WJ
haha right on man! that place gets pretty cold at night...
and i only trimmed my front bumper, the rear tucks just fine
Build Thread -
SOLD
alwaysHI is offline
post #5 of 51 Old 01-18-2012, 04:11 PM
shockracer
How did you get a 265/70/17 to fit in the spare tire well?
2001 WJ 60th anniversary edition 4.7 quadra-drive
5" hybrid lift, 265/70/17 Guard Dogs load E, bilsteins 5100's, addco sway bars, JKS front quick disco's, JKS adjustable track bar, KOR durometer track bar bushings, IRO crucial path front L.A.s, 1.25" Spidertrax spacers
Colorado Jeep Club Member #262
shockracer is offline
post #6 of 51 Old 01-18-2012, 06:36 PM
ct-snoman
2003 WJ
Interesting. Same setup yet I've never had problems with my washer bottle when wheeling. Never extended my bumpstops either
ct-snoman is offline
post #7 of 51 Old 01-18-2012, 07:54 PM
alwaysHI
2003 WJ
haaa??
you disconnected your front sway bar too?? i find that hard to believe you not eating fender lock to lock either.
Build Thread -
SOLD
alwaysHI is offline
post #8 of 51 Old 01-18-2012, 08:09 PM
JGC99
32's work fine on mine so far, but I don't have a lot of wheeling in yet. Same suspension setup.
JGC99 is offline
post #9 of 51 Old 01-18-2012, 08:21 PM
WeThePeople408
I just lifted my 04 with a 3" IRO and run 265/70/17's with no rubbing. However, I don't currently run discos. I have to admit it is a tight fit but looks great.
WeThePeople408 is offline
post #10 of 51 Old 01-18-2012, 10:22 PM Thread Starter
gtg413i
2003 WJ
it's a 245/70/17 spare that fits snug in the tire well to match the 265/65/17's. the cover sticks up unnoticably when the tire is fully inflated. Should have been more specific, but the tire diamaters of both are the same + / - 0.1"
gtg413i is offline
post #11 of 51 Old 01-19-2012, 07:13 AM
redwolf698
I have an 04 Overland with an IRO 3" lift and I run Goodyear Duratrac 265 75 17's. I have a TrailReady front bumper and have chewed the absolute CRAP out of the inner fender wells both front and rear. The treads have grabbed wiring harnesses, washer bottle and everything else under there at some point or another. I ended up putting on a set of spacers (I know, I know) to keep the inner tire from rubbing on the control arm during tight turns.
I would love to run 35's on my WJ, as I think it would look cool (this is my shop truck as well as my DD) but can't afford a damned Long Arm lift and $10,000 in upgrades.
Daniel J Fenti
Owner - NC Transmission
2004 WJ Overland lightly modified
Boat Drinks OffRoad Co-Founder
redwolf698 is offline
post #12 of 51 Old 02-03-2012, 04:31 PM Thread Starter
gtg413i
2003 WJ
Here's a pic of the tires mounted on my original rims. I'm getting closer. The tires look much larger now that they are mounted and I've got some trimming in my future. I also bought 1.5" spacers (jeepforum member) and zj washer bottle. More to come.
gtg413i is offline
post #13 of 51 Old 02-03-2012, 04:44 PM
metalhead
2011 WK
With my IRO 3 inch lift I run 255/70R17 on rubicon wheels and even with 1 inch wheel spacers I still hit the bumper when going over certain bumps. I have tried to trim as little as possible so it still looks ok but I guess now I may have to get more aggressive.
metalhead is offline
post #14 of 51 Old 02-03-2012, 10:47 PM Thread Starter
gtg413i
2003 WJ
Metalhead, can you measure your tire diamaters on the vehicle?
The reason I aski is I am only getting 31" diamater. Maybe it is because the wheel has some weight on it so it doesn't measure closer to 32", but when driving it will add some to the diamater.
The specs from BFG say they are 32.1" diameter with 19/32" or .6" tread depth.
gtg413i is offline
post #15 of 51 Old 02-04-2012, 07:40 AM
metalhead
2011 WK
I run falken rocky mountain ATs and they say 31.1". When I measure them they are almost exactly 31"
So im at 3" now and planning to go 4" to tack in the 32" duratracs w/ 16" steelies. blazepsi WJ Grand Cherokee Forum 2 10-24-2011 03:19 PM
How much to trim with 4" lift 33" tires? YZ212 WJ Grand Cherokee Forum 10 08-26-2011 11:39 AM
"Jeep", "Grand Cherokee", "4x4" and "V8" font question... Radosl81 WJ Grand Cherokee Forum 7 02-23-2011 03:37 PM
2" lift opinions kastner03 WJ Grand Cherokee Forum 9 12-29-2010 08:39 PM
pic of my laredo with 2" BB --31" tires and 15" rims MANUBI WJ Grand Cherokee Forum 9 08-26-2010 06:34 PM
