Open recall question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Open recall question
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineCount Down to KOH Sale!The Original 3/8" Ruffstuff Diff Cover!
Unread 08-23-2014, 12:30 PM   #1
patnewk76
Was using the Carfax open recall to use my VIN to check for any open recalls. Found 2 open ones, but here in lies the question. I do know that the motor in mine is not the original one. Would this in turn effect the recall? I'm guessing it probably will, but wondering if anyone on here has had any experience in this matter (different motor wise) It's recalls #882 and #B06
#882 deals with the REPROGRAM PCM OBD READINESS CODES
#B06 deals with the INTAKE MANIFOLD DEBRIS SHIELD
thanks in advance
91 YJ "Tonka" 4.0/ax15, stock/stock axles,
99 WJ 4.0 work in progress
patnewk76 is offline   Reply With Quote Quick reply to this message
Unread 08-23-2014, 02:45 PM   #2
losttech
losttech's Avatar
Go here make an account and you can see what recalls or you need have been done to your jeep and any work done by the dealer and your buildsheet very good info from Chrysler.
http://www.moparownerconnect.com/oc...nersLogin.aspx
2000 Jeep grand Cherokee
I6, selectrac, dana 30 front 44a rear
Stock not lifted.
losttech is offline   Reply With Quote Quick reply to this message
