open holes under doors from old cladding piece. - JeepForum.com
post #1 of 13 Old 11-12-2011, 08:30 PM Thread Starter
Crankcase
Wj open holes under doors from old cladding piece.
I took my lower cladding off a year ago on my laredo and I'm sick and tired of looking at the open square holes. Yah know, the piece that runs from tire to tire. I know the limiteds came without that cladding piece, and I'm assuming the holes are still there for the limiteds. Does anybody have the piece that covers the square holes?
Basically, is anybody parting out a limited and willing to ship the two sides?
Crankcase is offline
post #2 of 13 Old 11-12-2011, 08:32 PM
WJChris
WJChris's Avatar
a thin strip of vinyl stickers may cover it up enough for you.
What did you do for the outside of the doors?
WJChris is online now
post #3 of 13 Old 11-13-2011, 12:59 PM Thread Starter
Crankcase
Under the cladding was the body color and mine is white and I painted my cladding black, so it contrasted nicely.
post #4 of 13 Old 11-13-2011, 01:28 PM
Rocklobster
I pulled off mine when I put my sliders on. What I did was tape it off below the doors and satin black it to match the sliders.
However, I would also like to get ahold of thoes strips from the limited or at least the part numbers as I would like to keep out mud and snow, ect.
Rocklobster is offline
post #5 of 13 Old 11-20-2011, 06:38 AM
Rocklobster
Anyone have a part number ?
Sent directly from my brain using JeepForum
post #6 of 13 Old 11-20-2011, 07:22 AM
Thomahawk
2006 XK Commander
Found those square clips at ebay...
Buildthread
Thomahawk is offline
post #7 of 13 Old 11-20-2011, 08:04 AM
Rocklobster
Looking for the limited version of the door sill cladding :-)
post #8 of 13 Old 11-20-2011, 08:05 AM
Thomahawk
2006 XK Commander
I Think they are called rocker covers.
Buildthread
post #9 of 13 Old 11-20-2011, 08:14 AM
Rocklobster
They don't cover the rockers...
post #10 of 13 Old 11-20-2011, 08:27 AM
Thomahawk
2006 XK Commander
Ok, sorry then, mine does.
Buildthread
post #11 of 13 Old 03-14-2014, 11:59 AM Thread Starter
Crankcase
Just to revive a dead thread, I found at the junkyard an old limited. The limited had a long vinyl strips with double sided 3M tape. Cleaned it up and put it on, it looked OEM now. There is hope
post #12 of 13 Old 03-14-2014, 04:34 PM
multmigs
2003 WJ
how do they come off? I need to do this before I install my new sliders but I thought I would bedliner spray that whole area black since I have a light silver body and think its weird to have that showing below the door?
multmigs is offline
post #13 of 13 Old 03-14-2014, 06:10 PM Thread Starter
Crankcase
The vinyl strips I got from the junkyard Limited literally just peeled right off once I got one end started with a pocket knife. The vinyl strip is thick enough that pulling it off of the rocker panel won't do any hard. Some of the industrial double sided tape came with the vinyl strip, some remained stuck on the rocker panel. I used WD-40 to dissolve/remove the remaining sticky tape. cleaned it up and roughed it up with sand paper before applying new tape before I installed it onto my Jeep.
As long as you have a U-Pick junkyard in your area where you could find a limited, you'll be in luck!
If you want I could check my local junkyard in Buffalo NY for ya. Not promising anything though
Power to all doors and windows cut off when driver door is open Bubba3200 WJ Grand Cherokee Forum 5 09-02-2011 07:08 AM
Painted Cladding! 1999JeepLaredo WJ Grand Cherokee Forum 12 08-27-2011 12:34 PM
need a piece for rear cladding anyone know where to find it? JAC1502 WJ Grand Cherokee Forum 2 03-12-2011 09:59 PM
Covering holes below your doors? Moab4Life WJ Grand Cherokee Forum 7 01-19-2011 02:47 AM
GCL - "lift gate open" on display...not open though.... wheres the switch? JOSHMAN00 WJ Grand Cherokee Forum 2 08-24-2010 10:33 PM
