Omg... First time jeep owner lost #2 cylinder after two months!!!! - JeepForum.com
post #1 of 12 Old 12-09-2012, 09:05 PM Thread Starter
wincdub
I AM NOT mechanically inclined! What I know about my Jeep I have learned over the past couple months so please be patient with my ignorance.
My family purchased a 2002 grand cherokee limited 4.7l v8 in may and in July suddenly lost all compression in the number two cylinder. 100% leak down.
After removing valve cover and replacing spring the rocker arm will not stay in place. Valve is obviously stuck open. This is the extent of the work the shop did and they recommended a full engine replacement. They stated that the cost to pull the head and determine is there is block damage and get the cylinder machined and reinstallation costs are very nearly what a new engine would cost.
We have considered remanufactured engines as used engines are similar in cost and have less warranty coverage. But the cheapest quote we can get is $4600.
It has bothered me for a while that noone has even mentioned the option of replacing the cylinder head...
SOMEONE PLEASE HELP!!!
Chris
wincdub is offline
post #2 of 12 Old 12-09-2012, 10:12 PM
Lakoswolf
Hi Chris,
I think you may find more WJ assistance here: http://www.jeepforum.com/forum/f310/ as that section covers the 1999-2004 Grand Cherokee The ZJ (this section) covers the 1993-1998 Grand Cherokee. You may also wish to change your Jeep description as the XJ denotes the smaller Cherokee model Jeep. As far as engines go, I've heard nothing but good things about Jasper Engines and Transmissions but I've never dealt with them myself.
"Those who say it cannot be done should not interrupt the one doing it." -Chinese Proverb
93' Grand Cherokee 5.2 Ltd. - Mine
93' Grand Wagoneer 5.2- Dad's
93' Grand Cherokee 4.0 Ltd. (Deceased)
Lakoswolf is offline
post #3 of 12 Old 12-10-2012, 04:36 AM
Foundrydude
The valve may have damaged a piston, but you won't know that til it comes apart. There is cost to taking that gamble, and it's a big gamble. The most likely reason the valve won't close is that it's tweaked from contacting the piston
Unless you're doing your own work, the replacement engine is the way to go. If you wanna be cheap, get a used engine from a salvage yard.
Foundrydude is offline
post #4 of 12 Old 12-10-2012, 09:52 AM
Double E
Double E's Avatar
Sounds like another dropped valve seat.
A bore scope will tell for certain but the cause is often an overheat situation that went on too long, heated the piston, caused the steel valve seat to expand against the aluminum head & drop around the valve, preventing it from sealing and also....very likely break apart, damaging the piston and cylinder walls.
If it ever overheated on your family or the previous owner, there's probably a new radiator in there now..or if not, there also needs to be.
If they bought it in May and it failed #2 in July, ask about any overheats they had and what they did to stop the overheat... ask about the repairs done to it & why to get a full story.
Begin to source another engine.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #5 of 12 Old 12-10-2012, 05:08 PM
oldfamilyguy
Yes, a look inside will tell you want you need to know. You may be lucky and the dropped valve seat did not break up and that whats holding that valve open. The head would have to come off for the repair but probably worth it.
oldfamilyguy is offline
post #6 of 12 Old 12-11-2012, 03:52 PM
white_2003
1972 CJ5
http://www.powertrainproducts.net/do...engine-p/1.htm
This is the company we will be buying our engine from when (if) the wj gives up the ghost 2499.99 not bad IMO.
'12 JK, 3.6/NSG370/NV241/D30/D44, 2" Lift, 32" KM2's, 4.10's
'01 WJ, 4.7/45RFE/NV247/D30/D44A, 2" Lift, 32" KM2's, 3.73's
'72 CJ5, AMC 304/T-15/D20/D30/D44 2" Lift, 31" KM2's, 4.11's
'48 CJ2a currently under construction. (Wedding present)
white_2003 is offline
post #7 of 12 Old 12-11-2012, 03:55 PM
Jeepgcl9947
All I know is if you need a good drivers side cylinder head I got one forsale!
Jeepgcl9947 is offline
post #8 of 12 Old 12-11-2012, 04:52 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
Certainly not to the point of junking the motor IMHO.
Remove the head and have a looksie. Not hard to do DIY in my book.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #9 of 12 Old 12-16-2012, 12:20 PM Thread Starter
wincdub
I want to remove the head and troubleshoot myself to save money and try to avoid the more costly avenue of replacing the entire engine. We mostly want to just get it running and trade it back to the shady dealer we bought it from!!! Since it was from a dealer of course they deny the vehicle ever having any issues or even signs of concern prior to our purchase haha... At any rate we have decided to go for a reman engine if necessary as used engines are almost just as expensive and they have the mileage on them and lack the warranty of the reman units.
Since the #2 cylinder is on the passenger side we do not have much use for a driver side head at the moment but given my good fortune I may stand in need of one before Im able to get rid of this junk pile!
Any help regarding the necessary tools or a diy for dummies to help me stumble through my first venture taking off this cylinder head would be fantastic!! Thank you all for your input I realy appreciate it!
Chris
wincdub is offline
post #10 of 12 Old 12-16-2012, 12:26 PM Thread Starter
wincdub
Unhappy Omg... First time jeep owner lost #2 cylinder after two months!!!!
Chris
wincdub is offline
post #11 of 12 Old 12-16-2012, 01:02 PM Thread Starter
wincdub
These are pics of the cylinder and you can see that the rocker is loose in its position and can easliy be removed. Of course this is after whatever the ship did when I first took it in. They tried to replace the injector spring I believe and could not get the rocker to stay in and that is when they told me the valve was stuck open and quit working on it at that point.
wincdub is offline
post #12 of 12 Old 12-16-2012, 03:01 PM
Darnice
Valve bent, won't retract. In the first pic, that roller in the rocker looks out of place. Are those metal shavings on the cam?
Darnice is offline
cherokee , cylinder , engine , injector , misfire
