Ok some one help!! - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Ok some one help!!
All viair onboard air systems ship free to lower 48! Www.Spartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREEJEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFF
Unread 03-21-2012, 06:38 AM   #16
cherokee00SE
so it seems like i should hear it then? idk doesnt really sound out of the ordinary to me except when i first start it up..it sounds like the fan comes on full blast but it calms down quick.
if you dont think its the tps or a vacuum leak, what could it be?
cherokee00SE is offline   Reply With Quote
Unread 03-21-2012, 06:45 AM   #17
ezflip
I just had a smoke test done on mine. Cost was $30. He also told me if I think I fixed it and the code comes back, to take it back into him and he would do the smoke test again for me for no charge. First time I even took my Jeep to that shop. I think Ill go back lol.
BTW, your charcoal canister and vacuum lines are not behind the drivers rear wheel in your 2000. They moved them to that location in 02. Yours are in the engine bay drivers side, near the firewall. I wouldn't doubt there be a combination of things contributing. Get the smoke test done. If anything else, it will be good peace of mind for you. Also, what brand TPS did you use?
2002 Overland - 4.7 HO, "Select-Drive", 4" RC long arms, TAG front winch bumper, 32" BFG KM's
Build Thread KCCO
ezflip is offline   Reply With Quote
Unread 03-21-2012, 07:20 AM   #18
cherokee00SE
just one i picked up from autozone, i wanna say it was duralast.
Unread 03-21-2012, 07:23 AM   #19
cherokee00SE
and considering you had a smoke test done, i assume you had a vacuum leak? did you have symptoms similar to mine??
Unread 03-21-2012, 08:19 AM   #20
cherokee00SE
update- just disconnected the battery cables, held them together for 30 seconds, and let it sit disconnected for about 5 min. started it up, normal. put it in drive, normal. drove down the road and shifted in to all gears, normal. brought it back to the house and put it in park where it would normally shoot up to 1300, sat perfectly at 500. i hope to god this isnt just luck! thanks alot everyone for your info
Unread 03-21-2012, 09:14 AM   #21
jerrod710
2003 WJ
Whoops, forgot about that location. I'm used to messing around with mine.
jerrod710 is offline   Reply With Quote
Unread 03-21-2012, 09:16 AM   #22
jerrod710
2003 WJ
Awesome. It may be like mine. The codes were not cleared causing it to throw fits. Hopefully that takes care of it.
Unread 03-21-2012, 09:26 AM   #23
ezflip
Most likely it will come back. All you did was reset the pcm but if you have a faulty tps, resetting the pcm will force everything to work as fresh out of the factory until it relearns the thresholds of the new, faulty tps. Duralast sensors are crap when it comes to jeeps.
Build Thread KCCO
Unread 03-21-2012, 09:26 AM   #24
cherokee00SE
yeah we'll see for sure once i get off the back roads and go for a real drive with some length. it sure would be awesome
Unread 03-21-2012, 09:27 AM   #25
cherokee00SE
ezflip- if it comes back you think i should swap the tps with a mopar one rather than getting a smoke test for a vacuum leak?
Unread 03-21-2012, 09:29 AM   #26
ezflip
Yes, but I wouldn't discount a vacuum leak just yet either. Give it about 3-4 days, that's usually how long it takes to learn and start throwing codes again. Hopefully it doesn't come back for you.
Build Thread KCCO
Unread 03-21-2012, 09:35 AM   #27
ZJPunk98
Addicted to my Jeep
ZJPunk98's Avatar
I did not read the whole thread so bare with me if this is posted already.
Sounds to me like its the IAC. I have had similiar issues in the past due to failed/failing IACs. Sometimes the reving can be attributed to a failed TPS but you have replaced that already. The ECM uses input from at least four or more sources to control the idle: IAC, MAP, TPS, and the bank 1 O2 sensor.
Clean the throttle body, IAC, and MAP. I would also check the voltage at each sensor for proper functionality. This process is discussed in the Haynes manual. you will need a multimeter. remove the TB to clean properly and buy a new gasket for $3, this will ensure you do not have a vacuum leak.
Erik
98 ZJ 5.2L JGC Limited Sold
02 4.7L HO JGC Overland
ZJPunk98 is offline   Reply With Quote
Unread 03-21-2012, 09:44 AM   #28
ezflip
The iac can cause the idle issues, but generally will not cause shifting issues. The tps can cause every issue noted. That's not to say that the iac doesn't need to be cleaned or replaced, though.
Build Thread KCCO
Unread 03-21-2012, 09:47 AM   #29
cherokee00SE
ezflip- it never threw any codes though
ZJ- did it cause any shifting problems for you? i mean i had intense, hard shifts
Unread 03-21-2012, 09:55 AM   #30
cherokee00SE
oh and another question- what am i looking at price wise on a mopar tps?
