OK to ground here? Blue stud rear pass seat - JeepForum.com
post #1 of 2 Old 03-31-2011, 06:09 PM Thread Starter
ZB_WJ
I couldnt find this in forum. I hooked up an amp today. I hooked the ground up to a blue stud under the passenger seat? Is this ok? Not hooked up to the gas tank is it? It looks like a factory ground or something. I am not sure if you know if this is ok=, let me know. Thanks
ZB_WJ is offline
post #2 of 2 Old 03-31-2011, 06:30 PM
wsar10
2003 WJ
Pics are a wonderful thing..................
If you are referancing the lower seat mount (under the back seat bottoms), that bolts to the floor and through the floor, It will be ok.
straight chassis is perfection.... but that bracket is directly bolted all the way through the body to the outside by two bolts on each bracket, if I rememer correctly.
I think they are roughly 12 or 13mm, Unbolt one and sand under it's head down to bare metal.
QUOTE=billzcat1;wsar10 is right on point on this oil thread - as usual. Anyone reading this would be well-served taking his advice.
-03 WJ laredo 4.0 120k a few minor mods
-93 XJ 5spd, 3" zone lift
wsar10 is offline
Removing the rear seat head rests? HondaPeople WJ Grand Cherokee Forum 14 07-10-2017 12:22 PM
WJ: What size wheel stud and where to get them jclaudii WJ Grand Cherokee Forum 8 04-03-2014 08:21 PM
Rear Seat robtmiler WJ Grand Cherokee Forum 3 02-19-2011 07:49 AM
Pass rear door lock actuator str8shot WJ Grand Cherokee Forum 5 10-08-2010 09:43 PM
2001 WJ Wheel Stud Mystery bradbb2005 WJ Grand Cherokee Forum 18 09-10-2010 12:56 PM
