Which oil to use? - JeepForum.com
post #1 of 16 Old 07-07-2013, 07:14 PM Thread Starter
charleswilson90
2003 WJ
Which oil to use?
This has been beaten up and down on this forum but I just wanted to put it out there that I have been spending nearly $40 an oil change for the past 50k miles on my 4.0 for Mobil 1 high mileage synthetic. I just switched to Rotella T5, this Jeep sounds brand new! And it is half the price! Now if I could get Mobil to cut me a check for all that wasted money...
charleswilson90 is offline
post #2 of 16 Old 07-07-2013, 07:28 PM
Jer-Bear
I wouldn't use a pure synthetic. If you've run conventional it's whole life, switching can dry out rubber. Rear and front main seal, etc.
/ 2002 WJ 4.7 H.O. / Flowmaster 50 SUV / Magnaflow Cats / Rocking that 2WD! /
Jer-Bear is offline
post #3 of 16 Old 07-07-2013, 08:12 PM
rcwj04
^um..........
You forget that most members here don't own a crystal ball to tell you exactly what your problem is, specially with bad pictures that don't say/show much of anything... -Jacko84
Just a 19 year old kid with a Jeep, and broke because of it, and loving every moment.
2004 WJ Laredo 4.0 116k
2" BDS coils & Bilstein 5100's | Addco rear swaybar with energy bushings |
K&N FIPK | glasspack | plasti-dipped badges | 17" moabs | HID's, 245/65/17 Cooper Discover AT3 | Rola rack | Fawkes stand alone shackle tabs | Bed lined interior (what a pain that was)
rcwj04 is offline
post #4 of 16 Old 07-07-2013, 08:21 PM
pinky2252s
Hes been running a synthetic for 50k. Plus I have never heard of synthetic oils drying anything out.
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #5 of 16 Old 07-07-2013, 09:09 PM
jimh989
Really I don't think I would worry about it if you keep it changed all the time. Before I sold my i6 ZJ with 235k on it I ran straight 30w for two years. Well i the summer. 10w40 winter. I am thinking it may be time to switch the v8 wj from 5w30 to 10w30. It's at like 113k, I may give it a few more mile considering its alum. Heads....
Just keep it changed, my two cents
jimh989 is offline
post #6 of 16 Old 07-07-2013, 09:15 PM
coloradowjowner
Originally Posted by rcwj04
^um..........
x2
coloradowjowner is offline
post #7 of 16 Old 07-07-2013, 10:02 PM Thread Starter
charleswilson90
2003 WJ
Yeah I change it every 3k. I havent ever heard of synthetic drying gaskets? I was just posting this because of all the threads I read on here talking about which oil is best in the 4.0 and I was saying I'm on team Rotella is all. Cheaper, runs better. I guess I will see if it goes another 100k on the cheap stuff.
post #8 of 16 Old 07-07-2013, 10:56 PM
Planetcat
2010 WK
How would we know if synthetic would be ok or not without the OP even stating what the mileage is on his rig?
2010 WK Laredo 5.7L, 2004 WJ 4.7L (totaled), 1959 CJ-5, 1996 XJ (sold), 1989 YJ Wrangler 4.2L (Sold)
Planetcat is offline
post #9 of 16 Old 07-07-2013, 11:44 PM
Jrboarder27
How do you know Mobil 1 was a waste maybe its what has been keeping your jeep running so well. I can get six quarts of Mobil 1at wally world for under 30 bucks
Jrboarder27 is offline
post #10 of 16 Old 07-07-2013, 11:46 PM
Jer-Bear
It may or may not be true, but I've heard people say that after running conventional for a long time and switching can do this. It could be that it slips past things more, I don't know. I'm not even comfortable with a synthetic blend in mine.
Jer-Bear is offline
post #11 of 16 Old 07-08-2013, 04:48 AM
SteelBlue_WJ
SteelBlue_WJ's Avatar
This has actually happened to me... switched to full syn after 130K on conventional only. started having leaks and was recommended by my buddy who was a jeep service tech to switch back to conventional and all leaks stopped but i suspect my valve seals may need replacement now after that. I was told general rule of thumb is if it's been run on only conventional and it has at least x amount of miles on it, its better to stay on it or a blend, but not full syn.
Bobby
2001 Steel Blue WJ Laredo SA 4x4, 3.5" lift, Apperance Package with factory Laredo Steel Blue cladding/leather
Conferr Roof Basket with custom Randy Ellis Design light cage, WAAG grille guard and Hella lots of 500 lights
2004 Wrangler Sport, 2.5" and 31's, nothing special
"For all sad words of tongue and pen, the saddest are these, 'It might have been.' "
John Greenleaf Whittier
SteelBlue_WJ is offline
post #12 of 16 Old 07-08-2013, 08:59 AM
briandor
What you're actually seeing is not something being caused by the synthetic oil but something that already existed before putting the synthetic oil in. Synthetic oil is engineered to have smaller molecules. This is what makes it smoother and better at lubrication but it also gives it the effect of being thinner.
Rubber seals by their nature gradually break down over time as they shrink and harden and even crack. With a conventional oil it will take longer to see the effects of this (leaks) then it would with synthetic because the molecules of conventional oil are bigger and therefore harder to fit through the cracks and gaps in the aging seals. Now take those same aging seals and put synthetic in and the smaller molecules are now able to squeeze through the gaps and you have leaks. A good way to think of this would be to picture Jello on top of a window screen. For the most part it will not leak through the screen but as the Jello begins to warm and thin it will gradually start oozing through. Obviously leaks aren't good but they synthetic is also still providing it's benefit as well which is better lubrication.
I would tend to agree with remaining with conventional oil on an engine that has high mileage and always used conventional. At that point you're already passed the point where the benefits of synthetic would have much effect in engine life and really the synthetic would simply point out the wear and aging that has already occurred with an effect as you saw with additional leaks.
BTW, synthetic isn't going to cause any damage. Your valve seals will be in whatever state of wear they were before you put synthetic in. The synthetic doesn't cause seals to dry and crack or shrink any more than conventional would, which is to say it doesn't at all. Air and heat are actually what causes rubber seals to dry and crack. Oil of any kind actually helps to prevent and delay this.
As a side synthetic oil isn't really synthetic at all any more. Originally created from a purely synthetic base stock what is sold as full synthetic oil today is in fact conventional oil that has undergone a process called hydrocracking.
http://en.wikipedia.org/wiki/Synthetic_oil
briandor is offline
post #13 of 16 Old 07-08-2013, 10:02 AM
Jer-Bear
Uh huh...lol
Jer-Bear is offline
post #14 of 16 Old 07-08-2013, 10:19 AM
KayCeeJeep
Rotella is an excellent choice for the 4.0. Heavy duty and a thick 10w30, affordable, high in ZDDP and used oil analysis done when using Rotella in the 4.0 have shown very low wear numbers as well.
KayCeeJeep is offline
post #15 of 16 Old 07-08-2013, 10:22 AM
briandor
Uh huh...lol
Yea, I know. After I hit send I realized I wrote a book.
briandor is offline
