Oil Pressure Switch Location 4.7L V8 2001 Grand Cherokee - JeepForum.com
post #1 of 32 Old 01-10-2011, 06:36 AM Thread Starter
eneusiis
2008 WK
Hey Everyone,
New to the forum and found some helpful informaiton today on here, so I figured I would join and see if I can contribute.
I do have a current problem with my Oil Pressure Switch and I need to know where it is located. It is a 2001 Jeep Grand Cherokee Loredo 4.7L V8.
Anyone know where it is located? Any help would be appreciated.
Thank You!
Eric
eneusiis is offline
post #2 of 32 Old 01-10-2011, 06:44 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Just above the oil filter.
xjfever is offline
post #3 of 32 Old 01-10-2011, 07:23 AM
hxcjohnny
yea, just above the oil filter. It's reachable from top or bottom.
02 WJ Overland
hxcjohnny is offline
post #4 of 32 Old 01-10-2011, 07:43 AM Thread Starter
eneusiis
2008 WK
Thanks for the informaiton everyone, greatly appreciated. Being this is my first switch being replaced, should I also pull and drain the oil at the same time and replace it all and start fresh with a new switch even though the oil is about 1,000 miles old?
Thanks,
Eric
eneusiis is offline
post #5 of 32 Old 01-10-2011, 08:14 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
I would just replace the sending unit and leave the oil.
xjfever is offline
post #6 of 32 Old 01-10-2011, 08:39 AM
99WJNM
x2 on leaving the oil seems pointless to waste semi-new oil easy repair. and welcome to JF
99WJNM is offline
post #7 of 32 Old 01-10-2011, 09:10 AM
Bubba3200
It is easier if you take the oil filter off. Just get a qt of oil and a new filter. You will only loose the oil in the filter.
Bubba3200 is offline
post #8 of 32 Old 01-10-2011, 09:53 AM Thread Starter
eneusiis
2008 WK
Thanks everyone, I am off to the store and will report back the events of my knuckle busting.
eneusiis is offline
post #9 of 32 Old 01-10-2011, 10:00 AM
nlynd1978
2006 XK Commander
Get a mopar sensor from the dealer. Autozones and Advance'ed dont work right.
06 Commander Limited,4.7,130k
01 GC Limited,QD-II,4.0,236k-sold
99 GC Laredo,QT-II,4.7,96k-Sold
nlynd1978 is offline
post #10 of 32 Old 01-10-2011, 10:15 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
X2, I agree completely.
xjfever is offline
post #11 of 32 Old 01-10-2011, 01:16 PM Thread Starter
eneusiis
2008 WK
Does this take a "special" socket other than standard (Metric & SEA) Deep sockets?
2008 Jeep Grand Cherokee Loredo 3.7L
eneusiis is offline
post #12 of 32 Old 01-10-2011, 07:15 PM Thread Starter
eneusiis
2008 WK
Exclamation
So quick update, had to order the part overnight, so I thought I would get a head start and pull off the filter and assess the situation.
Jump back three weeks, I normally always do my own oil changes, however at the time, I was out of town 500 miles over due and pulled into a Penzoil Oil Change. Get the oil changed and now present day having oil pressure issues everything points to the Oil Pressure Switch.
So present time now, as I am looking up at the oil filter and all you hear from a mile in any direction is me SCREAMING "THOSE F*&%^$% IDIOTS!!!!!!!!!!!!!!!!!!!!
They put the INCORRECT oil filter. I mean this thing plane as day does not even look like it should fit, it is smaller and taller than what should be on there.
Needless to say that is probably what was causing the issue, but I will still replace the switch to be safe.
ALWAYS CHANGE YOUR OWN OIL IN MY OPINION.
eneusiis is offline
post #13 of 32 Old 01-10-2011, 09:25 PM
nlynd1978
2006 XK Commander
are you sure its the incorrect filter? i have heard there is a secondary filter for our jeeps that is a different size. i have read about it here and there. but it works just fine.
post #14 of 32 Old 01-11-2011, 05:49 AM Thread Starter
eneusiis
2008 WK
I have never seen in any referrence book or parts store another option for a different size filter or heard of that so I cannot comment. I have been changing the oil on this vehicle for 9 years and never once had a different filter or heard that. I will have to call the dealership to find out before I rip this manager a new one.
Can anyone confirm this for my vehicle? 2001 Jeep Grand Cherokee Loredo 4.7L V8.
eneusiis is offline
post #15 of 32 Old 01-14-2011, 05:50 AM Thread Starter
eneusiis
2008 WK
Wow, I wish I would have read this one before I had already put one the cheap version from Napa. Which then made my gauge read backwards....
You are completely correct on this one nlynd1978. I ended up doing the job twice and had to go to the dealer and buy the Mopar sensor and it works like new.
Thank you to everyone for your responses, you made the job easy and a cheap fix for me.
eneusiis is offline
2004 Grand Cherokee - PCM Location? mofeen WJ Grand Cherokee Forum 7 07-26-2010 09:26 AM
I need HELP with my 2001 Grand Cherokee!!! Brittnie WJ Grand Cherokee Forum 4 07-21-2010 10:07 AM
Looking to buy a 2001 Grand Cherokee 4x4 SHUG WJ Grand Cherokee Forum 2 05-14-2010 06:47 PM
2001 Grand Cherokee Lerado hlingar WJ Grand Cherokee Forum 3 05-14-2010 01:11 PM
Any opinions on 2001 3.1 TD Grand Cherokee? Case WJ Grand Cherokee Forum 2 03-22-2002 06:21 AM
