oil pressure switch location? - JeepForum.com
post #1 of 8 Old 01-15-2012, 04:17 PM Thread Starter
stressed
1977 J-Series Truck
So oil pressure was good, now drops to 0 with check gauges light on when idleing t light after warmed up. Sometimes gauges works, sometimes does not. Reads just under 40 or so when driving when it's acting up. Been driving for a while like this, no motor noise.
Where is the switch exactly so I can replace it? tools needed? i already have a new switch.
99 grand cherokee 4.0
stressed is offline
post #2 of 8 Old 01-15-2012, 04:55 PM
bds5
Should be right above the oil filter.
bds5 is offline
post #3 of 8 Old 01-15-2012, 07:41 PM
rickcricket
Actually in the 4.0 it is between the oil filter and firewall on the passenger side of the block.
Word of advice. Take the oil filter out. It makes the job much easier. Also don't forget to slide the little red tab before you get it off.
Get it from the dealer....have had problems with other ones.
rickcricket is offline
post #4 of 8 Old 01-15-2012, 07:45 PM
dnovack2007
would this switch cause the gauge to be pinned all the time?
dnovack2007 is offline
post #5 of 8 Old 01-15-2012, 07:53 PM
rickcricket
Mine would go down as soon as the engine warmed up or I came to a stop. It would read regular when I was on the gas.
post #6 of 8 Old 01-16-2012, 07:24 AM
dnovack2007
mine in maxed out all the time idle or on the gas.
post #7 of 8 Old 01-16-2012, 03:15 PM
rickcricket
You could actually have more of a problem then an oil pressure switch. I would start there and see what happens.
post #8 of 8 Old 01-16-2012, 04:24 PM
dnovack2007
what elese could it be? besides the gauge or a ground.
Oil Pressure Switch Location 4.7L V8 2001 Grand Cherokee eneusiis WJ Grand Cherokee Forum 31 12-22-2014 06:59 AM
4.7l Oil Pressure Switch #? jlmanatee WJ Grand Cherokee Forum 5 05-19-2011 08:30 AM
Switch mounting location and how to wire through the dash? JeeperCreeper94 WJ Grand Cherokee Forum 11 01-20-2011 07:47 PM
oil pressure sending unit location? WJ4fun WJ Grand Cherokee Forum 3 12-16-2010 03:32 PM
Oil pressure sensor location steelheart WJ Grand Cherokee Forum 4 12-08-2010 06:41 AM
