oil pressure sending unit, what were your symptoms? - Page 3 - JeepForum.com
post #31 of 55 Old 02-17-2014, 04:46 PM
JeepNowski
Somebody explain to me please.......
What exactly is meant by "dummy gauge"? Is it because the 1 wire sensor sends out 2 impulses? "Off and On"-ie; oil pressure and NO oil pressure?
Or is it something else?
One thing I noticed with mine old unit was it either had perfect oil pressure or zero oil pressure or was in between going from one of the two.
JeepNowski is offline
post #32 of 55 Old 02-17-2014, 05:23 PM
Jeeples
Jeeples's Avatar
More or less.
'99-'01 (or '02, I cant remember exactly) got a legit sending unit that gave fluctuating readings depending on oil temp, engine load, etc. The later WJ's got a dummy gauge that just tells you whether or not you have oil pressure. The readings will never fluctuate during the time the engine is running.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #33 of 55 Old 02-17-2014, 05:44 PM
Thomahawk
^^^Excactly how they Work, the 1 wire "dummy" gauge on 04's only shows if oil pressure are present or not, like an on/off switch.
Buildthread
Thomahawk is offline
post #34 of 55 Old 02-17-2014, 05:48 PM
JeepNowski
Ok, that's what I thought. Just wanted to make sure my understanding was correct.
post #35 of 55 Old 02-18-2014, 10:54 AM
poisoness
Originally Posted by Dmbish76 View Post
Hello I am having the same issue as u. Did you Change your sending sensor, did it stop the prob. Please help.
Thank you,
what happens if ypu don't replace it, if it works at 1200 rpms what the problem. it wont stop oil pressur from working. don't you think.
poisoness is offline
post #36 of 55 Old 02-24-2014, 11:11 AM
JGC99
Chalk me up to having this issue as well. It fluctuates, but checked the dipstick and oil looked normal. Anyone have the part number for a 99?
JGC99 is offline
post #37 of 55 Old 02-24-2014, 12:09 PM
JeepNowski
Don't know the part #, but do yourself a favor and get the mopar replacement. I've seen lots and lots of posts about the parts house sensor not working properly or failing prematurely. I got mine from the dealership and paid about $35.
Also double check the connector going into the sensor....1 wire is the dummy gauge, 2 wires is not.
post #38 of 55 Old 02-24-2014, 01:05 PM
Double E
Double E's Avatar
The OEM unit failed first, right? Maybe the OEM units are made better these days?
At least the parts stores will warranty their stuff.
I get about 3 years out of them tops.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #39 of 55 Old 02-24-2014, 01:16 PM
JGC99
Don't know the part #, but do yourself a favor and get the mopar replacement. I've seen lots and lots of posts about the parts house sensor not working properly or failing prematurely. I got mine from the dealership and paid about $35. Also double check the connector going into the sensor....1 wire is the dummy gauge, 2 wires is not.
Ok $35 isn't bad from the stealership. I'm pretty sure I have an actual gauge as mine is a 99 and it hovered around 20 for a bit then bounced around.
I'll go oem and just forget about it after. Lasted me 155k thus far. Maybe a good thing to change with the next oil changw
1999 Taupe Ltd 4.7L, 156,xxx miles, 3" IRO Lift, Rubicon take-offs, Carolina Driveline driveshaft
JGC99 is offline
post #40 of 55 Old 02-24-2014, 05:08 PM
2000_limited
My symptoms were when it was cold out side, like below 34 deg. The gauge would drop to zero while driving, but in neutral or park, it would go to normal. After driving for a while (like 50 miles or more) it would work fine again.
I replaced the unit and it has been fine since. I got mine from Rock Auto.com for about $32 including shipping.
2000_limited is offline
post #41 of 55 Old 06-03-2014, 08:12 PM
robertwhall
2014 WK
I had an oil change a couple weeks ago on my '00 GC (4.0L 6, 151k) and just in the last few days noticed the oil pressure gauge showing higher than normal....around 40-50 at idle and up to 70-80 at freeway speeds. One thing that makes me suspicious is if I turn the key w/ the engine off, the gauge goes up to about 45. Should be at zero if the engine is off and cold, I would think?
robertwhall is offline
post #42 of 55 Old 06-04-2014, 12:35 AM
Terminal
Amazing how these Heeps all have the same Fin' problems. I changed my oil two weeks ago with some cheap non-synthetic oil and wanted to drive on that oil for about couple hundred miles before dumping it and go back to synthetic so I could flush the engine. However, my oil pressure gauge is now reading 80 now when driving around.
Terminal is offline
post #43 of 55 Old 06-04-2014, 06:06 AM
Double E
Double E's Avatar
To me, it's not the Jeep's problem to have these sensors fail.
It seems making one to spec by the various parts manufacturers is where the problem is.
OEM, aftermarket, they all seem to give about 3 years. Again...it's who warranties them for replacement that gets me to a purchase.
Double E is offline
post #44 of 55 Old 06-05-2014, 08:41 AM
poisoness
Wj filter
Originally Posted by DaveRous View Post
I haven't gotten an opportunity to stick a manual gauge on the engine tonight (4.7 V8), but was looking for others experiences when your sending unit goes out.
I'm near 100% sure it's not my pump or major blockage(Although I'm running some seafoam in the crank case now to try and clean it before I drain the oil), since I made it about 50-60 miles home with my issues and had zero engine noises, excessive heat, or other things out of the ordinary. On start up my pressure seemed lower than normal, a shade over 40lbs and as the Jeep warmed up the pressure dropped and the check gages light came on. As I was traveling, any time I was on the gas or over 1200 rpms or so the pressure would rise to tops around 40lbs, which is lower than my normal readings, but still acceptable. When I slow down, as in coast, and come to a stop the gauge slowly drops until it reads around 1lb and the check gages light comes on.
That seemed to be the pattern on the way home, but there were periods when the gauge completely stopped working and read 0-1 for long periods, only to slowly raise up again randomly. Oil looks near perfect and isn't low, but there are about 3000 miles on it and the filter(Full synthetic/mopar filter).
as I said, I'm going to let the cleaner idle in the crank case for a bit, then follow the inspection/clean procedure for the sending unit hole and replace it with a new one. There was a bit of extra condensation on the oil fill cap that I noticed, but I've made a lot of short trips in this cold. There seems to be no coolant missing, and zero smoke coming out of the back regardless of engine speed. Anyway, just looking for any input from people that have dealt with issues like that before. Thanks!
I changed to a fram filter, haven't had a problem in over a year.
post #45 of 55 Old 06-08-2014, 10:56 PM
rrrcecc
OP, when you're oil pressure dropped did the temperature gauge slowly rise?
im having the same oil pressure problem you had, but when my oil pressure drops my temperature will slowly rise.
rrrcecc is offline
any way to put trans temp sending unit and tie it into the climate control wonderbrd937 WJ Grand Cherokee Forum 11 01-14-2011 01:31 AM
Backwards oil pressure after replacing sending unit? gonzo350 WJ Grand Cherokee Forum 10 12-17-2010 02:43 PM
oil pressure sending unit location? WJ4fun WJ Grand Cherokee Forum 3 12-16-2010 03:32 PM
Oil Pressure sending unit connector damage04 WJ Grand Cherokee Forum 2 12-10-2010 07:15 AM
Swap WJ oil sending unit? chrism1367 WJ Grand Cherokee Forum 3 05-10-2010 10:06 PM
