Oil Pressure Sending Unit - thread size - JeepForum.com
post #1 of 3 Old 06-05-2013, 02:08 PM Thread Starter
robin58
2015 JK Wrangler
I am pretty sure it's just the sending unit that's given out on my 4.7L 2004 WJ but figured I might as well put a mechanical gauge on it while I have it off to make sure.
Does anyone know what the thread size is? Is it standard 1/4" NPT?
robin58 is offline
post #2 of 3 Old 06-12-2013, 11:07 PM
berndog67
2003 WJ
ill post up in a few weeks the size, when i actually get some time to work on the jeep on something other than suspension stuff that is, because i plan on getting a new sensor and hitting my local hardware store to get a y or t pipe so i can also run an aftermarket sensor and gauge, so ill have a realtime oil pressure gauge, rather than the all or none ones us 02 and later guys have
2003 WJ Overland, 4.7HO, D30 & D44A (1 tons going in now!), RC Long Arm, lifted 4" Front 6" Rear, RC 2.2 4" Shocks, JKS track bar, custom hi-steer, 35" Procomp M/T's on JK rims, beefed up Overland rock rails, custom skids and dif gaurds, Rugged Ridge 8500 synthetic winch in custom hidden mount
berndog67 is offline
post #3 of 3 Old 06-13-2013, 06:42 AM Thread Starter
robin58
2015 JK Wrangler
It is indeed 1/4" NPT as I discovered once I got it off. I did exactly what you plan on doing. Put in a 2" nipple and a T fitting with one end capped. OPSU is now easily accessible as well as it being easier to get to the stupid clip, and I can get a mechanical gauge on it when I need to.
robin58 is offline
