Oil Pressure Sending Drops to 0 - JeepForum.com
post #1 of 5 Old 08-13-2017, 09:53 AM Thread Starter
JeepersMister
2006 WK
I've been helping a friend out with her recently purchased 03 WJ 4.7. It's been having trouble with the oil pressure dropping to 0 and check guages coming on.
The initial thought was a bad sending unit. But I'm thinking it might be a bad electrical connection. I think this because it only happens when going around a corner or down a steep hill. And when the pressure reading cuts out it's for no more than a second. Then it immediately pops back up to a normal reading.
Had anybody else experienced a bad connection issue with these? Where should I start looking to narrow it down?
-2006 Grand Cherokee Limited 5.7 Hemi
JeepersMister is online now
post #2 of 5 Old 08-13-2017, 11:01 AM
Topher11
Topher11's Avatar
99.9% it's the sending unit, they fail in a million different ways like that.. Start simple.
1999 WJ 4.0/6"/CLAs/33s/242SYE/ZJ Rad Swap
2006 LJ 4.0/2.5"/33s
Topher11 is offline
post #3 of 5 Old 08-13-2017, 01:01 PM
86cj74.2L
86cj74.2L's Avatar
You can always pull the connector off and spray it good with brake cleaner and see what happens. That plug catches a lot of junk. Oil, road dirt......
86cj74.2L is offline
post #4 of 5 Old 08-14-2017, 08:22 AM
halofreaks
Just be careful when pulling it off. It's difficult to get to on the V6 and there are TWO TABS! One is a sliding red locking tab and then there is another under it that needs to be lifted up and over a lock.
We are everywhere.
We are the Three Percent.
halofreaks is offline
post #5 of 5 Old 08-14-2017, 12:16 PM Thread Starter
JeepersMister
2006 WK
ok Great! Thanks for the heads up on this. I'm gonna try the connector first, and if that doesn't fix it I'll go for the sending unit. I'll advise as I go
