oil pressure question sender - JeepForum.com
post #1 of 11 Old 01-02-2011, 01:13 PM Thread Starter
jtcnj
I've searched this but can't find any specifics or pics. My oil pressure guage goes to 50psi when the ignition is turned to on, then goes higher, almost pegs when started.
I have a manual guage to verify oil pressure, I'm figuring on replacing the sending unit with an oem/ Mopar if the manual guage checks out.
With the oil filter removed, I still can't see the whole electrical connector, or figure it out by feel. So, I can't get the connector off. Also, is a special tool or socket need for this, or it feels like maybe 18mm.
Help?
"Lay Down Sally" Silverstone Metallic 2001 xj sport 4.0L/AW4/231/8.25 mostly stock.
"Dubyuh" or "Blue Bayou": Patriot Blue 2001 Up-Country WJ Limited 4.7L V8 Quadra Drive: for now known as "Al-Dente" after my wife's "mod".
New Addition 12/2011: "Pearl" Forest Green Pearlcoat 1999 xj SE 4.0L/AW4/231/8.25 mostly stock for now.
____________________________________________
I didn't agree, but hoped for Hope and Change.
I got change for myself and my family: for the worse.
This is the reality of: Barackalypse Now. Again.
"The most terrifying words in the English language are: I'm from the government and I'm here to help."
Ronald Wilson Reagan
jtcnj is offline
post #2 of 11 Old 01-02-2011, 07:19 PM
nickblack
It is definitely to the left of the oil filter near the firewall. It has a brass colored nut and u need a 1-1/16" deep well socket to pull it.
nickblack is offline
post #3 of 11 Old 01-02-2011, 08:09 PM
McGR
2007 XK Commander
I'm guessing that you are working with a 4.7 WJ - right? If so, check out this link for a diagram showing the sender location and other useful information:
http://www.jeepforum.com/forum/f13/i...1-4-7l-336206/
Also, the connector is most likely a locking style connector with the red locking mechanism that keeps the connector secure. If so, the small red locking clip must be slid over before the connector will release. See this link for details of a similar style locking connector:
http://www.bodyshopzone.com/archives...r_minivan.html
McGR is offline
post #4 of 11 Old 01-02-2011, 08:50 PM
Scibbyz99WJ
my 4.0 is the same way. i turn the key to on and before starting i notice the oil pressure rises to about 50, then pegs firmly at 75 once started
'99 stroked 4.5L WJ 2" BDS lift
2008 Fire Red F150 XLT 4X4 3V 5.4LV8
Closed minds should go hand in hand with closed mouths
Scibbyz99WJ is offline
post #5 of 11 Old 01-03-2011, 04:45 PM Thread Starter
jtcnj
Wj
Yes, its the 4.7. Thanks for the replies guys. I can't verify by feel if it has the locking tab or not, or if you squeeze or lift something. I can only see the back 1/4 or so of it.
I am guessing nickblack is refering to the 4.0, I didn't get a chance to look mine to see it it looks like the same connector setup.
So, anybody with specific info on the '01 4.7, please chime in!
jtcnj is offline
post #6 of 11 Old 01-03-2011, 05:50 PM
nickblack
Yeah, I meant the 4.0
post #7 of 11 Old 01-03-2011, 06:19 PM Thread Starter
jtcnj
Sorry, I didn't say which one, hey how did your area fare in the blizzard?
jtcnj is offline
post #8 of 11 Old 01-04-2011, 05:30 AM
nickblack
Believe it or not, we got only 6 in. I live jus south of I-287 and that seems to always be the cut off line for Noreaster storms. Just 2 towns north of here got 27" so we were lucky.
post #9 of 11 Old 01-04-2011, 07:40 AM
roach68
Mine had the red locking tab also and was a major PITA. I didnt even bother to put it back in, the locking tab that is. 4 months ago and still hasnt came loose. I should mention that mine was leaking from around the sensor and had a good bit of dirt and oil mix on everything, that could be why it was so hard to remove
roach68 is offline
post #10 of 11 Old 01-04-2011, 02:59 PM Thread Starter
jtcnj
Lucky is right! My back just stopped hurting from #^%$*@@ shoveling.
Thanks, I'll try to clean it up better and feel for the tab tomorrow. I'm off work. I'm signing up for Advanced Welding at the votec! Then I'll work on it a bit.
The phone rang while I was typing this: my wife is stranded, the xj wont crank! Great... gotta go.
jtcnj is offline
post #11 of 11 Old 01-04-2011, 04:09 PM
themow
nevermind
98 XJ 4.0 AX15 SOLD AND MISSED
03 Wj overland SOLD what junk!!!
06 wk 3.7
themow is offline
Tire pressure question hmmhoyhoy WJ Grand Cherokee Forum 2 12-27-2010 04:21 PM
02 4.7 HO Oil Pressure Sender Bubba3200 WJ Grand Cherokee Forum 4 12-05-2010 03:05 PM
Oil Pressure Question jrbrannan WJ Grand Cherokee Forum 6 09-29-2010 05:11 PM
Fuel pressure question Otto WJ Grand Cherokee Forum 2 05-04-2010 04:32 AM
Interesting...Problem or no? Oil Pressure Question mrmurphys WJ Grand Cherokee Forum 11 04-30-2010 02:57 PM
