Oil Pressure Gauge Dropping and Rising - Page 2 - JeepForum.com
post #16 of 20 Old 01-12-2013, 09:10 AM
2001WJv8
2015 WK
what pressure is it reading, what engine do you have? the acceptable PSI level for a V8 is anywhere between 7-80psi
'15 WK2 Diesel 4x4 ORII, Nitto TG2 275/65r18, BORA 1"f/1.25"r spacers, RRO super sliders
2001WJv8 is offline
post #17 of 20 Old 01-12-2013, 09:53 AM
ginobrownt
My engine is 4.0 straight 6. The oil pressure reads between 0-10. Sometimes the gauge light comes on
ginobrownt is offline
post #18 of 20 Old 02-07-2013, 12:55 PM
kdsimmons19
Where is the best place to buy a sensor? People reccomending Mopar but seems to be probs with their sensors. I've been throwing a 0523 code and occasionally my gauge reads no pressure.
Thanks guys.
kdsimmons19 is offline
post #19 of 20 Old 09-05-2013, 06:23 PM
VTech99
My replacement oil pressure sending unit sheared off as I was tightening, so I have the threaded "nub" still in the engine block with the rest of the sensor not connected. From underneath I can feel that some of the threads are exposed so I may be able to use a vise grip to twist it out. However, access from below is really tight. Does anyone know if there's a way to access from the top? Possibly by removing the airbox?
Thanks!
VTech99
VTech99 is offline
post #20 of 20 Old 09-05-2013, 07:21 PM
StormChaserTim
When I bought my 2000, it did exactly the same thing.....pressure on the gas, nothing at idle, with accompanying chime tone and warning light. So I got a sender off of RockAuto, and my problem turned upside down, hahahah.
Now I have no pressure when I hit the gas, and great pressure at idle. I have a replacement sender to install.
I'll gladly report back with my pressure readings when I get a sender in it that works, LOL
Tim
1995 Jeep Grand Cherokee Laredo, 4.0L 2WD, 355,000 miles.
StormChaserTim is offline
