oil pressure gauge - JeepForum.com
post #1 of 7 Old 09-12-2017, 04:18 PM Thread Starter
Pugulis
oil pressure gauge
My oil pressure gauge just dropped to zero, setting off the "check gauges" light and alarm. I then started working, then went off again. My engine seems to be running fine. Is this a common sensor problem with the 4.0 in a 2001, or should I be worried?
[_][]☺[][][]☺[][_] RIP to my 96' Grand Cherokee Laredo 344,700 miles and welcome to my new 2001 WJ
Pugulis is offline
post #2 of 7 Old 09-12-2017, 04:59 PM
WiLieR
It's going to die! Zero pressure means no oil moving and nothing good happens when no oil moves!
Just kidding. First thing to do is check the oil pressure sending unit. Chances are it has gone bad. It is an inexpensive part, so swapping it out would be the first thing I would do. It is a 15 minute job at the most. Easy to reach on the passenger side of the block near the oil filter.
Sent from my iPhone using Tapatalk
99 WJ Laredo - Mine once again!
WiLieR is offline
post #3 of 7 Old 09-12-2017, 05:29 PM Thread Starter
Pugulis
That's what I figured. Thanks!
Pugulis is offline
post #4 of 7 Old 09-13-2017, 08:59 AM
gamekiller7
Is it cheap? I swear I looked up on advanced Auto and the wanted $112
Sent from my XT1650 using Tapatalk
gamekiller7 is offline
post #5 of 7 Old 09-13-2017, 10:49 AM
Double E
Double E's Avatar
That's high. Should be about $40 IIRC.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #6 of 7 Old 09-13-2017, 03:38 PM
02WJJim
Oil Pressure Sensor
Make sure you buy an OEM MOPAR sensor (about $50) or you will be replacing it again very shortly. Ask me how I know! I believe it is a deep 21mm socket to replace this.
02WJJim is offline
post #7 of 7 Old 09-13-2017, 04:43 PM
Sociopath
Newbie
Sociopath's Avatar
I'll back up the buy a Mopar unit suggestion. Aftermarket sensors never seem to last, at least not on WJ's. I think they're coded to reject all aftermarket sensors lol.
I'm pretty sure a Mopar one is around $35 on Amazon.
Sociopath is offline
