Oil Pan Mysteries! - JeepForum.com
post #1 of 6 Old 03-20-2012, 10:09 AM Thread Starter
sevenkev
Wj Oil Pan Mysteries!
Hello all. This is my first post here, thanks in advance for all who've posted here before.
I'm replacing the rear main seal on my 2003 Jeep Grand Cherokee I6. While attempting to drop my oil pan I've noticed two bolts that I can't remove - because I have no idea what kind of tool to use. They are the bolts that hold the oxygen sensor harness to the oil pan, on the passenger side next to the exhaust headers. They are also holding the oil pan to the engine. They have 5 "star" like ridges. What are these? I'm stumped.
Also, on the bracket that holds the oil pan to the engine (closest to the bell housing) there is some kind of rubber flange attached. In all of the other pictures/videos I've seen I haven't run into this flange. What piece is this? Is it crucial? You can see in the photo that I cracked mine while taking it off.
Thanks to all -my WJ will be on jack stands until I can figure these out!
sevenkev is offline
post #2 of 6 Old 03-20-2012, 10:48 AM
whosyadadie02
Is it the v8 or I6?
That nut looking peice looks just like a little retainer that you should be able to unscrew with a needle nose.
Idk what that other peice is off hand
whosyadadie02 is offline
post #3 of 6 Old 03-20-2012, 11:03 AM Thread Starter
sevenkev
Thanks for the reply! It's an I6, fixed my post. It could be a retainer but I was unable to unscrew it with any type of pliers. Other bolts for the oil pan look like the one below, with the nut attached to the bolt, so I'm wondering if the mystery bolts are the same way?
sevenkev is offline
post #4 of 6 Old 03-20-2012, 11:16 AM
WiCkeDuDe
There just pushnuts. Just twist them off or use a pick to remove them. They either were used to hold something during assembly or someone was too cheap to find some correct nuts and used those.
I Have WJ Stuff for Sale
WiCkeDuDe is offline
post #5 of 6 Old 03-20-2012, 12:36 PM
Double E
Double E's Avatar
A screwdriver tapped against the flared up part will get them to turn.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #6 of 6 Old 03-20-2012, 01:18 PM Thread Starter
sevenkev
Awesome. Thanks for the replies. I'm not worried about damaging a simple retainer/pushnut so I'll have at it. Will report back.
Now if I can only identify that flange that is on the oil pan mounting bracket..
sevenkev is offline
