Oil Leaking Top of 4.0L - JeepForum.com
post #1 of 8 Old 10-06-2013, 01:56 PM Thread Starter
Colton5419
I have been noticing that oil is leaking from the bases of the two hoses on top of my 4.0L engine - I have been just shrugging it off and keeping an eye on it, I mean this thing has leaked oil since I got it with 61,000 miles. (now at 68,800).
First oil change I had a shop do, and it leaked then too, but this time I did it and it still does this.
What would cause this? I was thinking maybe I put too much oil in (manual said 6 quarts so I put in 5.5 and checked the dipstick; it looked over, so I drained even more from the bottom.. still said overfull on the dipstick but I just don't see how? I'm positive 5 quarts or more drained because I put the used oil in the 5.1 quart container and it was more full than when new.
My engine is nicely coated with mud from a recent off-road excursion after a rain storm; so now it's very easy to see where the oil is running down.
Image:
04 GC Special Edition - 4.0 I6 - Quadra-Trac II
(OlllllllO)
Colton5419 is offline
post #2 of 8 Old 10-06-2013, 02:47 PM
coloradowjowner
My gaskets/grommets that the hose fittings go into we're dry and unable to seal against the valve cover. I purchased some new ones and the blow by stopped.
Do be aware the plastic fitting that goes into those grommets will most likely break. This will made me have to by the whole vacuum hose set up for there. It was pretty cheap like $30 or something near that and the dealership had to order it. So keep that in mind before you go trying to remove anything that might break.
coloradowjowner is offline
post #3 of 8 Old 10-06-2013, 03:51 PM
nickblack
You can buy the 2 plastic grommets for $2 at Autozone. Maybe the holes in them got clogged up making the crankcase unable to vent. Replace them. Make sure the right one goes in the right hole, they are different.
nickblack is offline
post #4 of 8 Old 10-06-2013, 03:57 PM Thread Starter
Colton5419
Anyone have a link to them?
I don't know exactly what the parts would be called that I would need to buy - I'm trying to find it on autozone.com
And when replacing them, what are the steps involved? Do I just pull them out?
(OlllllllO)
post #5 of 8 Old 10-06-2013, 03:58 PM
new2site
I had them leaking and my valve cover gasket...replaced all three at once... you might want to do all three as well (valve cover off of engine) being those are a nightmare trying to take out without them crumbling (which of course pieces will fall down on top of valves).
And getting replacements in without damaging them was tricky as well...had to carefully/strategically hammer with wood block.
This guy has his technique with replacing them on engine:
http://www.jeepforum.com/forum/f310/...ite-up-733669/
new2site is offline
post #6 of 8 Old 10-06-2013, 04:19 PM
new2site
CCV Elbow with fixed orifice: #47057 (This one I believe is the correct but "will come up" as incompatible with WJ's ...think that's an error in auto parts system..when in reality is compatible..you'll have to verify this)
Fresh Air Elbow: #47079
Grommets: #42344
new2site is offline
post #7 of 8 Old 10-06-2013, 04:28 PM
new2site
If you decide to do the valve cover gasket while you're at it ..see video at 6:00 below for how cables come off throttle body:
new2site is offline
post #8 of 8 Old 10-06-2013, 05:29 PM Thread Starter
Colton5419
Awesome video, thank you!
Would this be a potential area for slight loss of MPG?
(OlllllllO)
