Oil Filter Leak, Sender? - JeepForum.com
post #1 of 12 Old 05-17-2011, 09:49 AM Thread Starter
MaintMech
Old and in the way
MaintMech's Avatar
Wj Oil Filter Leak, Sender?
I'm doing some work on my son's 2001 4.7L Limited. I noticed an oil leak by the filter. I'm not sure if it's the filter (doubtful) or the sender above it. I'd like to know if that is an oil pressure sender or some other Jeep sensor. When I do the filter it'll be a lot easier to change with the filter off. About all I can tell you is that it has two wires coming from it.
Thanks in advance for any and all help.
'96 Grand Laredo, 4.0, Stock, Daily Driver
I fought Oracle and Oracle won!
Originally Posted by coralman
If the faith isn't there,the doubt is.
MaintMech is offline
post #2 of 12 Old 05-17-2011, 10:46 AM
boomersoonerGC
You may also check the PS pump right above there. Its common for it to leak on the 4.7's. I am experiencing this problem myself.
boomersoonerGC is offline
post #3 of 12 Old 05-17-2011, 11:37 AM
TSyl
The sensor right above the filter is the oil pressure sending unit. Common for the to go out. I have 2001 4.7 too, did mine last summer. And yes, it is MUCH easier with the filter off.
TSyl is offline
post #4 of 12 Old 05-17-2011, 12:20 PM Thread Starter
MaintMech
Old and in the way
MaintMech's Avatar
Wj
Thanks for the input folks. Off to NAPA we go.
I'd get it from Rock Auto but can't wait on the mail delivery.
post #5 of 12 Old 05-17-2011, 01:09 PM
TSyl
By the way, I forget what size (1 1/16" I think) but you will want to have a deep socket handy for removal/installation.
TSyl is offline
post #6 of 12 Old 05-18-2011, 10:15 AM
Double E
Double E's Avatar
Remove the electrical connector before taking off the sending unit. The red clip has to slide out in order to push the release for the connector. (Red clip needs to be thrown out upon reinstallation for when the sending unit fails next time.)
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #7 of 12 Old 05-18-2011, 11:27 AM Thread Starter
MaintMech
Old and in the way
MaintMech's Avatar
Wj
Double E, I assume you are being a little sarcastic when you say throw away the red clip?
If not please explain.
Thanks!!
post #8 of 12 Old 05-18-2011, 01:22 PM
KayCeeJeep
That red clip is a real devil, I threw mine away. That connection doesn't want to come off very easy even without it on there.
Be careful with the new unit if you get aftermarket, it is quite easy to break them. Ask me how I know...
KayCeeJeep is offline
post #9 of 12 Old 05-18-2011, 04:44 PM Thread Starter
MaintMech
Old and in the way
MaintMech's Avatar
Wj
O.K. I get it. Thanks!
I guess if it was easy it wouldn't be a JEEP!!
post #10 of 12 Old 05-18-2011, 05:33 PM
straty1987
i might have to check if mine is leaking when the rain end on Sunday, i have a leaking valve cover and oil making its way down slow but no drips or loss of oil yet.
its under Oil Pressure Switch?
i remember people saying to only use mopar oen or will have the light on, is the wrong?
straty1987 is offline
post #11 of 12 Old 05-18-2011, 06:15 PM
xJoshxx
2012 WK
Mopar tends to read right.
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #12 of 12 Old 05-19-2011, 10:35 AM
Double E
Double E's Avatar
Oil pressure sending unit is what it may be listed as.
Mine reads fine. I've used a few types and they read pressures like OEM.
Double E is offline
P0146 Evap Emission Leak (small leak) wildman4x4nut WJ Grand Cherokee Forum 4 01-31-2011 03:50 PM
oil pressure question sender jtcnj WJ Grand Cherokee Forum 10 01-04-2011 04:09 PM
Amsoil Air Filter to replace factory filter box? mrJ WJ Grand Cherokee Forum 32 12-29-2010 11:41 AM
02 4.7 HO Oil Pressure Sender Bubba3200 WJ Grand Cherokee Forum 4 12-05-2010 03:05 PM
