Oh man! How do I get at that Crankshaft Position Sensor '99 Grand Cherokee 4.0 L - JeepForum.com
post #1 of 35 Old 05-29-2005, 08:20 PM Thread Starter
cjdietzman
Question Oh man! How do I get at that Crankshaft Position Sensor '99 Grand Cherokee 4.0 L
Hello, and thanks for checking out my plea for help.
Well, I think I have located the crankshaft position sensor on my 1999 Grand Cherokee 4.0 L. When I get under the truck on the driver's side, I think it is up on the bell housing...with one bolt on it and an electrical pigtail. So, how the heck do I get at that thing??? I have seen other threads in this forum, where guys talk about replacing it by going through the top. I will be dammed if I can figure a way to get at that darn thing through the top. It looks hard enough trying to get to it from the bottom!!! Anyone have any hints or tips??? I would greatly appreciate it guys. FYI, the replacement sensor that I purchased from Autozone today looks very different. It came with some other type of bracket, with 2 bolt holes. The sensor on my truck appears to have just one bolt. Oh man, I was hoping this would be much easier. I hope that I don't end up having my truck towed to a shop. Let me know if you can help. Thanks for reading my little thread.
cjdietzman is offline
post #2 of 35 Old 07-19-2011, 08:54 PM
bond-jamesbond
2003 WJ
2003 4.0 Crankshaft Position Sensor EASY replacement!
EASY!!! After cutting the crap out of my hands and inventing new curse words removing the old Crankshaft Position Sensor from my 2003 Grand Cherokee 4.0, I could not get the bolt back in with multiple extensions and swivels.
I figured there MUST be an easier way, something the stealership is not letting on about.
Fact is, if you go through the firewall under the dash it is EASY!!
Here's how to do it:
1) Remove the plastic bottom panel directly under the gauges. It simply snaps up and out.
2) Locate the bolts and screws that hold the lower plastic panel under the steering column and remove them to free up the panel. Remove the panel.
3) Look behind the center console toward the front and you will see a small plastic "L" shaped duct that blows air to your feet. Snap it out of its position and remove the phillips screw holding it from under/behind (or cut the plastic flange with a razorknife halfway if the screw is hard to get at - takes a shorty phillips screwdriver. This way you can still snap it back on.)
4) Pull the carpet back and tuck it under the gas pedal.
5) You will see 2 oval metal plates that are attached to the firewall for the shifter and accelerator cables to pass through. Remove the 2 10mm nuts from the upper one that the shifter cable passes through and pull the plate back.
6) VIOLA! There is the crankshaft position sensor staring you right in the face through the hole in the firewall you have exposed!
7) Insert a 10mm socket with extension and remove/replace the CPS mounting bolt with ease.
You guys are welcome to buy me a beer when we cross trails
bond-jamesbond is offline
post #3 of 35 Old 07-20-2011, 06:27 AM
svons7
Ha where was this thread a few weeks ago... i did it the hard way and went from the bottom.
Thanks for the info jamesbond.
1996 Grand Cherokee Laredo 4x4. Np242. 3.5 IRO Benchmark. 15x8 Crager soft 8s 4in BS. 31in Goodyear Wrangler Duratracs
svons7 is offline
post #4 of 35 Old 07-20-2011, 07:13 AM
1stblack97ZJ
I think he's got it figured out by now jamesbond. This thread is 6 years old.
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline
post #5 of 35 Old 07-20-2011, 01:12 PM
Corrupt
But still some good info.
***If you try to fail and succeed, then which have you done?
***RIP Ratmonkey!!***
Corrupt is offline
post #6 of 35 Old 07-20-2011, 02:18 PM
speedbucket
hey now, it is old.....but look at it this way
he is a noob:
that actually USED the search function!
and his first post was of superior quality
welcom to the forum
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #7 of 35 Old 07-20-2011, 02:27 PM
sabzz
lol I didn't realize how old it was til Black said something. I was getting ready to answer it
1998 ZJ 4.0 work in progress/DD
'97 ZJ 4.0|3.5 RC|31" -SOLD
sabzz is offline
post #8 of 35 Old 07-20-2011, 02:44 PM
1stblack97ZJ
that's why I make it a habit of checking now haha.
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
post #9 of 35 Old 07-20-2011, 03:39 PM
gothchick
At least he actually used the search function. Props. Lol.
Don't fear the regear.
Finished 4x2 --> 4x4 conversion.
gothchick is offline
post #10 of 35 Old 07-20-2011, 08:07 PM
narnwv
narnwv's Avatar
it's better to resurrect old threads full of useful information than starting new ones.....
~Aaron
narnwv is offline
post #11 of 35 Old 07-20-2011, 08:11 PM
the88thpianoman
2003 WJ
he is a noob:
welcom to the forum
This this this this this!!
Bond, welcome to the forum, and seriously, thanks for the pro tip!
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #12 of 35 Old 07-20-2011, 08:34 PM
dmextreme77
Wow. Very nice!
2001 Grand Cherokee 4L
-4"RC
-265/70 Treadwright's on JK Moabs
-Bunch of misc crap
dmextreme77 is offline
post #13 of 35 Old 07-22-2011, 04:58 AM
deanlad1980
other people might need his advice?
deanlad1980 is offline
post #14 of 35 Old 07-22-2011, 05:19 AM
wsar10
2003 WJ
X2,
on all of the above
thats a damn good tip, and if it works it should be a sticky or in the FAQ's
you gotta realize we jeepers have been fighting this CPS location for 10yrs !
QUOTE=billzcat1;wsar10 is right on point on this oil thread - as usual. Anyone reading this would be well-served taking his advice.
-03 WJ laredo 4.0 120k a few minor mods
-93 XJ 5spd, 3" zone lift
wsar10 is offline
post #15 of 35 Old 07-22-2011, 07:45 AM
georged
If someone uses this method, how about pictures please
georged is offline
2002 Jeep Grand Cherokee Crankshaft Position Sensor jmonro3 ZJ Grand Cherokee Forum 7 02-28-2011 01:48 PM
need to know where the crankshaft sensor is on a 1993 jeep grand cherokee laredo.... PDOGEMP ZJ Grand Cherokee Forum 6 09-28-2010 11:05 PM
ZJ Grand Cherokee Crankshaft Position Sensor SUCCESS!!! camelman ZJ Grand Cherokee Forum 1 12-17-2007 10:46 PM
Crankshaft position sensor & coolant temperature sensor getting replaced in my 95 GC Keith1975 ZJ Grand Cherokee Forum 3 12-14-2006 03:52 PM
1994 jeep grande cherokee auto replacing crankshaft position sensor mikemedic ZJ Grand Cherokee Forum 3 12-02-2004 07:02 AM
