OEM Copper Plugs, I'm a believer! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > OEM Copper Plugs, I'm a believer!
Unread 03-14-2014, 02:56 PM   #1
cjcyr8
Wj OEM Copper Plugs, I'm a believer!
Just tuned up my 2004 GC, WJ, Laredo 4X4. I used the NGK OEM copper plugs. The last time I tuned it up was 45,000 miles ago, and ignorantly used Champion 3034 single plats. Since I've been a member of the forum I've been schooled about spark plugs. I wish I would have taken these 3034's out sooner. The Jeep performs better in every single way, especially idle...Here is what I am confused about, and my question: Why the hell does Champion spec 3034 single plats for our vehicles (WJ 4.0's with DIS ignition)???
cjcyr8 is offline   Reply With Quote Quick reply to this message
Unread 03-14-2014, 04:22 PM   #2
multmigs
2003 WJ
Is that plug listed on your actual tune up decal under the hood?
multmigs is offline   Reply With Quote Quick reply to this message
Unread 03-14-2014, 04:28 PM   #3
ezflip
ezflip's Avatar
Doesn't really matter if they are NGK or Champion, as long as they are copper! The 4.0 and the non-HO 4.7 do not like platinum. Parts stores list them as OEM because they are more expensive and sound like an "upgrade".
~James
2002 Overland - 4.7 HO, "Select-Drive", 4" RC long arms, TAG front winch bumper, 32" BFG KM's, 3" exhaust, Magnaflow hi-flow cat, Flowmaster 50 series
Build Thread
ezflip is offline   Reply With Quote Quick reply to this message
Unread 03-14-2014, 04:50 PM   #4
cjcyr8
yes, the NGK is what is listed on the decal. Purchased from Rock Auto
Unread 03-14-2014, 05:50 PM   #5
wsar10
2003 WJ
^^This......
Most people dont care much about there vehicle and just listen to what a parts store clerk tells them is OK
There lazy and thats the easy way !! This is the growing trend here in the US ......
QUOTE=billzcat1;wsar10 is right on point on this oil thread - as usual. Anyone reading this would be well-served taking his advice.
-03 WJ laredo 4.0 120k a few minor mods
-93 XJ 5spd, 3" zone lift
wsar10 is offline   Reply With Quote Quick reply to this message
Unread 03-14-2014, 06:44 PM   #6
86cj74.2L
86cj74.2L's Avatar
DIS and fancy plugs sometimes don't match because one of the plugs is always firing backwards.
There is nothing different ignition wise that I could find between the HO and non-HO other than plugs. (Most likely for heat dissipation)
My non HO has has autolite double platinums. For 5 years and 35,000 miles.
86cj74.2L is online now   Reply With Quote Quick reply to this message
Unread 03-14-2014, 06:55 PM   #7
fiveseven15
parts clerks are terrible. had a car that required iridium (evo x) and had to argue with the guy for 5 mins that platinum was not okay.....
fiveseven15 is offline   Reply With Quote Quick reply to this message
Unread 03-14-2014, 07:28 PM   #8
Jrboarder27
Originally Posted by wsar10 View Post
^^This......
To many people go to auto parts stores and put they're trust in the people behind the counter. Not realizing the extreme incompetence.
Jrboarder27 is online now   Reply With Quote Quick reply to this message
Unread 03-14-2014, 08:17 PM   #9
2ndhandWJman
2003 WJ
BINGO! There are times when the factory knows what's best,
2ndhandWJman is offline   Reply With Quote Quick reply to this message
Unread 03-14-2014, 08:27 PM   #10
cjcyr8
three of the old plugs wore down to 0.040 and the other three were at 0.050.....after 45,000 miles...
Unread 03-15-2014, 10:55 AM   #11
grussell
Copper is the best conductor for spark plugs and they tend to wear out faster than other plugs with harder metal. Copper plugs are also less expensive so replacing them more often is okay.
2001 GC Laredo 4.0 4x4 - Black l 2001 GC Laredo 4.0 4x4 - Silver
grussell is offline   Reply With Quote Quick reply to this message
Unread 03-15-2014, 12:30 PM   #12
wsar10
2003 WJ
The FSM says avg gap increase of .001 per 2k mi.
I wouldn't concern myself with .040-.050
IIRC OE gap is .35 ????
FWIW I did a 10k test with using MMO (as there was question around about the effects of MMO and fouling plugs or temp variances )and here are my plugs @ that 10k mi mark
http://www.jeepforum.com/forum/f310/...o-use-1260329/
