OEM or aftermarket Crankshaft Position Sensor? - JeepForum.com
post #1 of 23 Old 08-30-2010, 10:19 AM Thread Starter
BigBadDad
Question OEM or aftermarket Crankshaft Position Sensor?
I'm still struggling with this problem on our 2000GC/4.0. I am thinking of letting a local garage tackle it for me. they want to install an OEM part from the dealer. Said the aftermarket ones available at the parts stores are no good and will not warranty them. Any body else had trouble with aftermarket sensors? (Quite a bit of dollar difference)
BigBadDad is offline
post #2 of 23 Old 08-30-2010, 10:55 AM
WiCkeDuDe
WiCkeDuDe's Avatar
Only use a OEM sensor. You will save yourself headaches.
I Have WJ Stuff for Sale
WiCkeDuDe is offline
post #3 of 23 Old 08-30-2010, 05:20 PM Thread Starter
BigBadDad
OK, but what is the difference? The ones Advance auto sells have a two year warranty, and labor is included if done at an Auto Repair shop. What is the warranty on the OEM Mopar part, which is what failed in the first place?
(Just wanting answers from those with experience. Thanks for the help. Things are really tight right now and a $300 repair is NOT in the family budget!)
BTTT
post #4 of 23 Old 08-30-2010, 05:56 PM
ras2001wj
ras2001wj's Avatar
The aftermarket sensors and jeeps just don't get along. You will see many, many threads where aftermarket sensors have failed within the first month or have made problems worse.
I had my transmission done a few months back, and because of periodic problems (once every few months, it would have trouble starting), I went ahead and had the mechanic put in a new Duralast sensor, and the problem started happening every start, he couldn't even keep it running), so he put the OEM one off the used transmission in and it has worked fine ever since. (knock on wood)
Rick
2001 WJ Laredo 4.0
2" BB
245/75R16
Ron Paul
2012
"Freedoms Popular"
ras2001wj is offline
post #5 of 23 Old 08-30-2010, 06:25 PM
WiCkeDuDe
WiCkeDuDe's Avatar
OEM sensors have better tolerances and should be used on Jeeps for critical sensors like a CKPS or oxygen sensor, they save alot of hassles over cheaper and less accurate sensors. You can try it of course, but there are alot of threads with strange problems. From personal experience I would say only use a factory Mopar CKPS.
post #6 of 23 Old 08-30-2010, 07:51 PM
TJSWJ
oem or bust! ive used them all Autozone, Federated, O-rileys, every one ive installed on customers cars. On my jeep its OEM only because of problems ive seen with aftermarket. I had a brand new duralast one be bad right out of the box.
TJSWJ is offline
post #7 of 23 Old 10-31-2012, 03:59 PM
OnTheFence
When you say OEM, are you saying just buy from dealer, or is there a certain brand that is OEM for a given sensor?
OnTheFence is offline
post #8 of 23 Old 10-31-2012, 07:42 PM
mycreativename
I currently have an aftermarket one in my Jeep. It's been working just fine for a year now.
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline
post #9 of 23 Old 11-01-2012, 02:55 PM Thread Starter
BigBadDad
I am the OP on this topic. I installed an aftermarket from Advance Auto, and it has been fine ever since! I did get aggravated and "cheated" on the installation. I cut a hole through the driver floorboard to make it easier to access. Gotta be careful, there is either a fuel line or brake line right there that you got to avoid! (I forgot which one it is now)
post #10 of 23 Old 11-01-2012, 03:03 PM
Jrboarder27
Mopar is the OEM brand for jeeps, there are a lot of websites sell Mopar parts.
Jrboarder27 is offline
post #11 of 23 Old 12-22-2013, 10:18 AM
FordExplorer
what sensor was that? speed sensor on the transmission?
FordExplorer is offline
post #12 of 23 Old 12-22-2013, 11:19 AM
Ravie
The crankshaft position sensor reads the flywheel and it is mounted on the bellhousing of the transmission rather than the engine.
1999 WJ - Over 10k on the 4.0 rebuild. FB/BDS 2" lift (2.5") w/Bilstein 5125's. General Class Ham...KC0LUA
Burlbook48 sez "Nothing moves a project along faster than cubic dollars." Certified Thread Killer.
Ravie is offline
post #13 of 23 Old 06-25-2014, 12:41 PM
93zjer
Does mopar actually manufacture their own parts? I believe someone else makes the parts for them?
93zjer is offline
post #14 of 23 Old 06-25-2014, 02:02 PM
swkenobi
2003 WJ
Use the OEM, they work and are not that much more expensive.
2003 Grand Cherokee Limited - Mostly Stock
swkenobi is offline
post #15 of 23 Old 06-25-2014, 04:26 PM
93zjer
The question is, what is OEM?
It seems that Delphi made the OEM CPS for MOPAR?
Not that much more expensive is very relative. Im a college student who trains in multiple martial arts. Training and competitions are expensive.
If I can save $20 and still get OEM that makes a difference for my gf and I.
93zjer is offline
How do you get at a 4.7L 99 JeepGCL crankshaft position sensor SierraNev WJ Grand Cherokee Forum 19 07-03-2016 06:37 PM
4.7 Wacky Idle fixed with new Throttle Position Sensor riverview6067 WJ Grand Cherokee Forum 98 09-29-2015 02:11 PM
WJ Throttle Position Sensor Replacement spreadhead14 WJ Grand Cherokee Forum 6 06-02-2010 05:02 PM
99 WJ 4.7L where is the cam position sensor cj847 WJ Grand Cherokee Forum 2 02-01-2009 04:50 PM
Replacing a Throttle position sensor? Grazsrootz WJ Grand Cherokee Forum 7 08-07-2007 01:17 AM
