Odometer reads noflsh - JeepForum.com
post #1 of 7 Old 03-10-2013, 04:44 PM Thread Starter
GolfGuns
Wj Odometer reads noflsh
Had to do some work inside the drivers door panel and left the ignition switch after testing the electric windows (duh). I completely killed the battery so had to jump it which was no problem. After I jumped it, the odometer stays lit with noflsh.
I unhooked the neg overnight really thinking this would work but no change. Unhooked both terminals for about and hour and no luck there. I have checked the PCM fuse and the instrument fuse under the dash and they are fine.
Anyone have anymore suggestions?
Thanks
GolfGuns is offline
post #2 of 7 Old 03-10-2013, 04:51 PM Thread Starter
GolfGuns
Nevermind, I guess the 3rd time is a charm. I unhooked the neg and let it sit a half hour or so and it worked.
GolfGuns is offline
post #3 of 7 Old 03-10-2013, 05:27 PM
USFORCES
1/2 an hour? It only takes 10 minutes.
04 Overland on 33's, Lift & tires= 8" over stock.
USFORCES is offline
post #4 of 7 Old 03-10-2013, 05:54 PM
Locutus
2014 WK
retracted
Locutus is online now
post #5 of 7 Old 03-10-2013, 06:12 PM
Locutus
2014 WK
snip
post #6 of 7 Old 03-10-2013, 06:40 PM
gcjeeping
gcjeeping's Avatar
Isnt there something about unhooking the battery and turning on the lights that resets something or something like that.
Would be helpful if you had a buddy with a wj so you could try his cluster in yours to rule out the cluster.
_____________
gcjeeping is offline
post #7 of 7 Old 03-10-2013, 06:47 PM
gcjeeping
gcjeeping's Avatar
Also have you tried the cluster self check?
Hold the odometer reset button in and turn the key to ignition (not start). The odometer will run thru some numbers and warning lights will illuminate.
Also read through this thread...
http://www.jeepforum.com/forum/f11/g...orking-847887/
Also see if there are any hidden codes in the ODBII.
Retrieving codes: Turn the ignition key until the digital odometer displays, repeat three times in succession and then back to "On" (On/Off, On/Off, On/Off, On). At the fourth "On" the odometer will be replaced with codes. If no codes are present then "Done" will appear.
_____________
