odometer not working - JeepForum.com
post #1 of 9 Old 05-17-2011, 05:01 PM Thread Starter
tex2281
2003 WJ
Angry odometer not working
Not sure what is causing this but my odometer and trip meter have not been working since i bought it from my father inlaw. He said it was working and then just quit one day. I have taken the cluster apart and none of the contacts look like they are burnt, all the fuses are good. Everything else works in the instrument cluster and on the digital display above. Any suggestions would be great. I was going to try and clean the contacts on the ecm and see if that would work.
tex2281 is offline
post #2 of 9 Old 05-17-2011, 06:15 PM
adamcorey
I wouldn't touch until it's time to sell. I wish my odometer stopped a long time ago.
2004 WJ. Limited. 4.7 H.0. fully loaded 255/75-17 BF Goodrich mud Terrains. K&N intake. Flowmaster dual side exit exhaust. Clarion door speakers with 12" pioneer sub. Rear flip down DVD with surround sound. 2.5 inch Rustys coils installed with 2 inch BB in the box waiting on extended sway bar links. Addco rear sway bar. Uniden CB. Viper 2 way alarm w/ dei start. It holds 5 guys with hunting and fishing gear and tows a 24 ft. Bass Tracker all at the same time.
1995 ZJ laredo 4.0 235/75-15 BF Goodrich all-terrains. K&N FIPK. Dynomax cat back. pioneer deck w/ 12'' bazooka sub(not the tube). rear integrated fog lights for night time surf fishing. roof and front bumper mounted rod holders. replaced--stock springs and shocks, alternator, starter, crankcase sensor, fuel filter, pads and rotors, front u-joints, thermostat, radiator hoses. tranny went so i traded it for the big boy above.
adamcorey is offline
post #3 of 9 Old 05-17-2011, 07:38 PM
CarlJH
2003 WJ
to test the cluster push the trip reset button while you turn the ignotion on, this will do a self test of the gauges and warning lights.
all the needles will do a full sweep. hows the abs? as the speedo gets its info from the abs tone ring as well.
CarlJH is offline
post #4 of 9 Old 05-17-2011, 07:51 PM
ExoticFish
If you figure out what the problem is let us know so I can break mine. Lmao
http://www.VAJeeps.com
ExoticFish is offline
post #5 of 9 Old 05-17-2011, 08:50 PM
dafox
x2
dafox is offline
post #6 of 9 Old 05-18-2011, 12:25 PM
FleshEater
2014 JK Wrangler
This is excellent for you since they're talking about taxing each motor vehicle on miles traveled. Keep it broke and don't tell anyone...in fact have a mod delete your thread.
2014 JKU Rubicon *DAILY DRIVER*
Gone but not forgotten; 2005 LJ *SOLD* 1987 XJ *SOLD* 2002 WJ *SOLD* 1995 ZJ *SOLD*
FleshEater is offline
post #7 of 9 Old 05-18-2011, 03:01 PM
shepd
LOL, I bet new ABS speed sensor rings with about 3/5th the teeth will become very popular if such a law ever happens. You could then gauge your speed via the kph printed on the odometer and enjoy a 38% tax break. You could go even further than that, but I imagine then you'd want to fit some sort of separate GPS based speedometer.
shepd is offline
post #8 of 9 Old 05-19-2011, 07:01 AM Thread Starter
tex2281
2003 WJ
Still haven't figured out what's wrong so I'm just leaving it alone if I do find out what caused it I will let you know how to make it not work
tex2281 is offline
post #9 of 9 Old 05-19-2011, 09:20 AM
99SK04GTX
I was an expert at reaching under the dash of my fathers 69 El Camino and popping off the spedo cable. I was 15 and wanted to drive, what can I say!
99SK04GTX is offline
1-6 designations above Odometer kadetklapp WJ Grand Cherokee Forum 11 01-24-2011 12:45 PM
HELP!!! 4WD not working exrm193 WJ Grand Cherokee Forum 11 12-27-2010 05:34 AM
Odometer rolling backwards. iluvtruenos WJ Grand Cherokee Forum 12 11-01-2010 11:37 PM
engine stalling and trip odometer resetting itself ry1820 WJ Grand Cherokee Forum 16 05-24-2010 07:19 PM
odometer question f1probe WJ Grand Cherokee Forum 8 03-09-2004 02:04 PM
