OBDII still showing P0161 and P0158 even after changing O2 sensor. - JeepForum.com
post #1 of 16 Old 07-13-2013, 08:11 PM Thread Starter
DCJosh
Question OBDII still showing P0161 and P0158 even after changing O2 sensor.
Hey everyone. Since I bought a YJ recently and the weather has been nice, the WJ has been sitting for a while.
I took it out for a drive and I got a MIL (Check Engine).
Went to Advance auto and they told me I have the P0161 and the P0158 codes. I changed the sensors and the check engine light is still on.
I went back to Advance borrowed the OBDII again and thought that I could just clear the code. Did that, but it only lasted for a little while until the MIL came back.
I did just learn that I could cycle the key off and on a few times and it would show the fault on the odometer. Kind of a cool feature.
What are my options? I have searched but I don't come up with any solid answers for my case in particular.
I have a 2003 Overland with the 4.7HO.
Thanks for any help that you can give.
- DC Josh
DCJosh is offline
post #2 of 16 Old 07-13-2013, 09:30 PM
rm2001wj
rm2001wj's Avatar
I changed the sensors ...
Those codes refer only to one (bank 2 sensor 2) of the 4 O2 sensors. Are you saying that you changed them all? or just one? If only one, are you sure it was the correct one. BTW, with those codes, most likely there is a problem with a couple of the wires for that sensor shorting together.
rm2001wj is offline
post #3 of 16 Old 07-13-2013, 09:50 PM Thread Starter
DCJosh
I changed both of the sensors that are just after the small catalytic converters. They are the ones that are close to each other on the passengers side.
(I actually got the information from you in a thread from 2009!)
I did the code check by cycling the key and not it says that I am just getting the P0158 code.
Would taking my battery cable off to reset the ECU help? Any more ideas?
DCJosh is offline
post #4 of 16 Old 07-14-2013, 12:08 PM Thread Starter
DCJosh
I solved the issue by disconnecting the battery from both positive and negative terminals, wait for a few minutes, and then connected them up again. I then drove around the beltway and tested everything out.
The MIL did not come on during the 60 mile trip.
I will repost if it comes on again within the next few days, but I think this may have solved the issue.
DCJosh is offline
post #5 of 16 Old 07-14-2013, 12:19 PM
USFORCES
Mine did it too until I disconnected the battery, never came back.
04 Overland on 33's, Lift & tires= 8" over stock.
USFORCES is offline
post #6 of 16 Old 07-16-2013, 07:29 PM Thread Starter
DCJosh
The MIL came up again today. I bought a scan tool and it is showing the P0161 code as the primary and the P0158 as a pending code.
Is there a chance that it is because I used a Bosch sensor?
Any thoughts?
- DC Josh
DCJosh is offline
post #7 of 16 Old 07-16-2013, 07:33 PM
MeanGreenZJ
Yeah, Try denso or NTK Unfortunately a Bosch 02's seem to make a Chryslers run worse. They seem to be okay replacements in a vehicle that used them from factory ie some GM's toyota's etc but the heater element in them doesn't run hot enough to satisfy the pcm requirements.
Any thoughts?
- DC Josh
MeanGreenZJ is offline
post #8 of 16 Old 07-16-2013, 07:52 PM Thread Starter
DCJosh
If that's the case, does anyone know Auto Zones return policy...?
DCJosh is offline
post #9 of 16 Old 07-16-2013, 11:22 PM
snowman91
2003 WJ
If it has a warranty they will give your money back. But you can pick up ntk from napa
snowman91 is offline
post #10 of 16 Old 07-16-2013, 11:40 PM
CopperDeer
Sounds like it could be a wiring short like mentioned, though. Try swapping both downstream O2 sensors with each other and see if the code follows the sensor (to the other bank) or stays on bank 2. Then it would really suggest a wiring issue.
CopperDeer is offline
post #11 of 16 Old 07-17-2013, 05:27 AM Thread Starter
DCJosh
The problem with that is the sensors have different electrical plugs at the ends...
The Bosch sensor did have a more 'universal' type plug, I will try to swap that one over and see if it follows.
DCJosh is offline
post #12 of 16 Old 07-17-2013, 06:27 AM
rm2001wj
rm2001wj's Avatar
What did you have to do to make the Bosch "universal" plug connect to the WJ harness plug?
rm2001wj is offline
post #13 of 16 Old 07-17-2013, 10:09 AM Thread Starter
DCJosh
I did not have to do anything to it. It fit over the WJ harness tabs that stick out in the random locations.
DCJosh is offline
post #14 of 16 Old 07-20-2013, 09:45 AM Thread Starter
DCJosh
Update to what I have been dealing with.
Autozone took back the Bosch O2 sensor with out the receipt or the box, so that is good.
What is bad is, I purchased a Denso O2 sensor (the same that the dealer wanted) and installed it and I am still getting the P0161 code.
Will it disappear within a certain number of times I start and run the Jeep? Should it go off automatically?
Is there a fuse that I could check? I'm at a loss again, any help is appreciated.
DCJosh is offline
post #15 of 16 Old 07-20-2013, 09:57 AM
Jaspah
I don't think the code will go away instantly. You have to drive it a certain distance or time or clear it using a code reader..
Jaspah is offline
