o2 sensors - JeepForum.com
post #1 of 24 Old 09-01-2014, 12:01 AM Thread Starter
craft2004
o2 sensors
hi guys my jeep is running lean cause I can smell it every time I get out of it and the fuel mileage has suffered also. I have changed the TPS sensor, the idle air control valve, I've cleaned the intake, changed the plugs and coil packs. it run and drives but seems to be running a little rough then when I first bought it. it has a 4.7 v8, my next move is o2 sensors. what o2 sensor are which like bank 1 sensor 1 idk which one that is. thanks
craft2004 is offline
post #2 of 24 Old 09-01-2014, 12:11 AM
jetrinka
Is the CEL on? What proof do you have its running lean other than your highly trained nose? Smelling it is likely a rich condition.
jetrinka is offline
post #3 of 24 Old 09-01-2014, 12:37 AM Thread Starter
craft2004
whoops I meant rich and yes the cel is on
post #4 of 24 Old 09-01-2014, 05:43 AM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
1/1 is the drivers side pre cat sensor before the cat and 1/2 is the drivers side after the cat. 2/1, 2/2 are the ones for the passengers side.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #5 of 24 Old 09-01-2014, 07:53 AM
86cj74.2L
86cj74.2L's Avatar
What is the CEL
86cj74.2L is offline
post #6 of 24 Old 09-01-2014, 08:42 AM
JMZ101586
Originally Posted by 86cj74.2L
What is the CEL
Check
Engine
Lamp
Google is your friend.
Stable:
04 WJ Special Edition 4.7
98 Camaro SLP SS with LS2 swap
05 STS4 4.6 Northstar AWD
JMZ101586 is offline
post #7 of 24 Old 09-01-2014, 11:02 AM
jetrinka
What code is it setting? Rich conditions are a bit harder to diagnose than lean conditions. Is it running badly?
jetrinka is offline
post #8 of 24 Old 09-01-2014, 11:49 AM
86cj74.2L
86cj74.2L's Avatar
Originally Posted by JMZ101586
Check Engine Lamp Google is your friend.
Ok how about the P code then.......I know what it stands for..........
post #9 of 24 Old 09-01-2014, 11:57 AM
jetrinka
jetrinka is offline
post #10 of 24 Old 09-01-2014, 01:05 PM Thread Starter
craft2004
its not running terrible but I can notice it and I still have to get the codes read. thanks for clearing up the o2 sensor info for me
post #11 of 24 Old 09-01-2014, 02:24 PM
86cj74.2L
86cj74.2L's Avatar
Just do the key dance.
post #12 of 24 Old 09-01-2014, 02:52 PM Thread Starter
craft2004
whats the key dance
post #13 of 24 Old 09-01-2014, 03:28 PM
86cj74.2L
86cj74.2L's Avatar
whats the key dance
turn on and off the ignition three times without starting it and leave on the third time.
The odometer will become your code reader.
It will flash numbers and when finished display DONE.
post #14 of 24 Old 09-01-2014, 03:52 PM
JohnnyV
If you smell gas it could be leaking fuel injector.
2002 WJ Limited 4.7L - Inferno Red
1995 ZJ Laredo 4.0L
1989 XJ Laredo 4.0L - Sold
JohnnyV is offline
post #15 of 24 Old 09-01-2014, 04:46 PM
Uniblurb
Uniblurb's Avatar
My 04 4.7 also smells like fuel from the exhaust at idle with a slight miss but no codes. I installed new plugs last Fall but not sure if I have a bad new plug or maybe coil pack? I read in the FSM the coil pack resistance is .6 - .9 ohms for primary and 6K-9K for secondary but it didn't mention exactly how you're supposed to test this? Can someone please explain this test and I am familiar with my multimeter? Thanks!
Sorry and not trying to hijack this thread but just saw o2 sensors mentioned in the title. Thought I'd mention when I bought my 4.7 exhaust from Nick/Kolak he said if you end up with a bad o2 sensor you best fix/replace it pretty fast before it trashes the cat(s).
How ya doing 86cj74.2L and glad to see you still have your sense of humor!
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 96 4.0 XJ (son's)
Uniblurb is online now
