NP242 Shifting Freely?! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > NP242 Shifting Freely?!
Save 5% Off Of All Orders In August - Promo CodeJeep Wrangler Bushwacker Flat Fender Flare Sale at BaselinTJ & LJ Safari Cab Hardtops - $450 off expire 8/31/201
Unread 04-01-2015, 09:16 PM   #1
chevalier426
I just rebuilt the back cv joint on my rzeppa front driveshaft and bolted it back in. I went for a test drive and went to shift into 4 part time and full time and the shifter moved back and forth without any resistance. Its stuck in 2wd but the shifter isn't stuck, it somehow slides freely. Anyone have a clue what the issue might be? Could I have hit some linkage bolting the shaft back in or something?
chevalier426 is offline   Reply With Quote Quick reply to this message
Unread 04-01-2015, 09:23 PM   #2
mr312712
SPEED FREAK V8 FOR LIFE.
mr312712's Avatar
Check the linkage.
If one day the speed kills me, don't cry. Because I was smiling.
Limited to 118 MPH for now.
Castrol Edge 10W30 Full Synthetic
04 WJ Overland 4.7 H.O. Inferno Red AWD/4WD
mr312712 is offline   Reply With Quote Quick reply to this message
Unread 04-01-2015, 09:28 PM   #3
chevalier426
Originally Posted by mr312712 View Post
Check the linkage.
I haven't tried that yet since its pretty late. I'll check tomorrow. The linkage is off the left side of the t-case, right? How would I adjust it if needed?
Unread 04-01-2015, 09:32 PM   #4
mr312712
mr312712's Avatar
I have the 247 but Im sure the linkage Is on the left like mine.
Unread 04-01-2015, 09:49 PM   #5
chevalier426
Im pretty sure they're the same, just wanted to be sure. I think I may have hit it when I was moving the shaft around above the yoke to get the axle end in. I probably hit something then I am assuming. Thanks for the help
Unread 04-01-2015, 09:54 PM   #6
mr312712
mr312712's Avatar
Your
