04-12-2012, 09:00 PM
#1
Not looking forward to the replies
'00 larado 4.0 select-a-trac
Was on my way home had the heat on full blast I noticed that the air flow went from front vents to defrost and back all within maybe 3-4 seconds it's never done that before and it seams fine now but it was only a five minute drive also it's not dual climate any thoughts I hope it's not the blend doors
04-12-2012, 09:24 PM
#2
It's a lack of vacuum on the AC/cruise control vacuum line. Inspect or replace the line, and add a check valve.
The check valve didn't work for me, so I'm looking at adding an extra vacuum reservoir on that line.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here: Life lessons and budget build
04-12-2012, 09:26 PM
#3
If you dont have dual climate then you dont have blend doors...
04-12-2012, 09:31 PM
#4
Where can I find the vacuum lines and Chris I did not know that thanks for the info I feel stupid lol
04-12-2012, 10:06 PM
#5
Not correct,he just doesnt have dual climate to have seperate temps on each side of his interior.He can still control whether he has hot or cold or warm air with his temperature knob.And that means theres a door to blend the air,and they can fail.
04-12-2012, 10:10 PM
#6
Is this a common problem For my type of hvac system
04-12-2012, 10:16 PM
#7
But we know it's not the blend door b/c he's not complaining about temp. problems... and I haven't read a single case on here of someone without dual zone having a blend door break... so it's a pointless argument.
Did the change take place while you were accelerating? If so read this..
http://wjjeeps.com/climate.htm
Heater A/C system changing to defrost mode when accelerating - 1999-2000 models (see TSB # 242499)
http://wjjeeps.com/tsb/tsb_wj_242499.pdf
EvilEagle - "Imaguy3 just made everyone in this thread his b*tch."
04-12-2012, 10:23 PM
#8
I believe it was when accelerating I live off a state highway so I have to get on it to make a left ill have to look for these vacuum lines tomorrow
04-12-2012, 10:26 PM
#9
Check for a vacuum leak like posted above.
04-12-2012, 10:58 PM
#10
Sounds like an intermittent vacuum leak, I replaced the vacuum line under my battery tray because it was cracked. Once completed I got my AC Controls and Cruise Control back.
04 Freedom Edition - 4.0\SelecTrac
08 MazdaSpeed 3 - 38k Miles - 343whp\21lbs Boost (For Sale)
There is a learning curve to everything.
04-12-2012, 11:34 PM
#11
Yep, typical vacuum line problem, easy fix.
Bear - 1999 Jeep Grand Cherokee Laredo - 250,000 Miles, BDS 2" lift, Overland rock rails, Dynomax cat back exhaust, 245/75/16 Kumho KL78's, Rebuilt 4.0 @ 244,000 miles.
Apollo - 2008 Mazdaspeed3 - Mazdaspeed CAI, Mazdaspeed CBE, Prosport boost gauge.
Velvet - 2005 Ford Focus ST - Wifes ride
04-13-2012, 06:10 AM
#12
Sorry, meant he doesnt have the blend door problem
04-13-2012, 04:22 PM
#13
This is the only vacuum line I can find and it looks fine am I just not looking in right place and FYI my cruise control is working
04-13-2012, 04:46 PM
#14
Check the ones going to the intake manifold and that whole area. I had one pop off once.
04-13-2012, 05:23 PM
#15
read the TSB... it talks about placing a check valve in the vacuum line, your lines may be fine, it mya just need that valve
