is this normal - JeepForum.com
post #1 of 10 Old 08-05-2011, 02:34 PM Thread Starter
willy45015
is this normal
Ok with a/c on my temp creep over 210 almost to the firstis this normal line
willy45015 is offline
post #2 of 10 Old 08-05-2011, 02:46 PM
4Tom
creep over 210 to what temp. ?
WJ 2001 3.1TD
Tom
4Tom is offline
post #3 of 10 Old 08-05-2011, 02:55 PM
tbone1004
we're in the middle of a nasty hot summer, you're adding strain to the engine with the AC on. If you're doing around town driving I wouldn't say it's abnormal. If you're on the highway I'd be a little concerned. I wouldn't worry too much about it if it's only up a few degrees
tbone1004 is offline
post #4 of 10 Old 08-05-2011, 07:37 PM Thread Starter
willy45015
Like it in between 210 an the next line on gauge an yes it more in the city where I notice it but I always heard to not over heat the 4.7 cuz there pop even by little
post #5 of 10 Old 08-05-2011, 07:40 PM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
When mine started to creep up over normal I found that I had a bad electric fan.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #6 of 10 Old 08-05-2011, 07:43 PM Thread Starter
willy45015
I'll have to check it out tomorrow after work didn't even think about that electric fan
post #7 of 10 Old 08-05-2011, 07:47 PM
michiganmaveric
Got Beer?
2011 JK Wrangler
Mine was still spinning but not as fast as it should have been. My brushes were worn and a grove had got worn into the motor commutator (sp). Of course I had about 200,000 miles on it.
Lifetime member #13
post #8 of 10 Old 08-06-2011, 09:05 AM
4Tom
It should sit at 210 and at idle or slow driving when temp rises the e fan switches on. The e fan also switches on when using AC.
It sound like you e fan isn't turning on. Most common fault is e fan relay.
WJ 2001 3.1TD
Tom
4Tom is offline
post #9 of 10 Old 08-06-2011, 09:15 AM
shepd
Don't 2000 WJs have a clutch fan?
shepd is offline
post #10 of 10 Old 08-06-2011, 10:31 AM
narnwv
narnwv's Avatar
99-2000 4.7s have a mechanical clutch fan AND an electric fan. In 2001 both fans were replaced with the hydraulic fan that's driven from the power steering pump.
~Aaron
narnwv is offline
