Noise under rear passenger wheel - JeepForum.com
post #1 of 9 Old 05-02-2013, 09:21 PM Thread Starter
tonydotigr
Wj Noise under rear passenger wheel
Greetings!
I recently started to get this rattle when going over bumps on rear passenger wheel area. I replaced the shocks so I'm confident its not this. The muffler also looks well secured. Any other ideas what it might be? It happens when going over bumps with speed and almost seems like a slight rattle. Could it be the sway bar? Many years back I believe this was upgraded. Just curious if others have experienced.
Thanks all.
'03 Jeep Grand Cherokee Limited
126K miles
tonydotigr is offline
post #2 of 9 Old 05-02-2013, 09:48 PM
USFORCES
It's the aftermarket shocks, clunk in the rear is caused because the bolts are smaller than the bolt sleeves.
This is what I used to fix it when mine did it.
http://www.kevinsoffroad.com/cart/wj...of-four-p-153/
Belvidere, IL cool I'm in rockford.
04 Overland on 33's, Lift & tires= 8" over stock.
USFORCES is offline
post #3 of 9 Old 05-02-2013, 11:45 PM
85IrocZ-28
Aftermarket shock bushings are narrower than factory. Most people just place 2 or so washers in between the shock bushing and mount...that's what I did, and it has worked well.
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY ---
85IrocZ-28 is offline
post #4 of 9 Old 05-03-2013, 12:15 AM
USFORCES
I tried that first and it didn't work for me they still rattled, I ended up buying the sleeves and bolts.
USFORCES is offline
post #5 of 9 Old 05-03-2013, 03:13 AM
wj_runner99
Had the same issue! All I did was back the bolt out a little and put some thread locker on em'. Then used a breaker bar and tightened the hell out of them. That was a tear ago and haven't had an issue since.
wj_runner99 is offline
post #6 of 9 Old 05-03-2013, 04:55 AM
scross1220
2012 WK
Could be the right rear parking break assembly. I just had the issue. You will need to remove the rotor to check but i am sure that might be it.
______ooooo
/__l_l_,\____\,___
l_---l_l__l---[o]llllll[o]
_.(o)_)__(o)_)--o-)_)
If you're not fixing it, you're not driving a Jeep.
scross1220 is offline
post #7 of 9 Old 05-03-2013, 06:36 AM
Merc1973
What about the swaybar endlinks or even the evap canister? The mounting plates rust out and it could be knocking around in there...
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #8 of 9 Old 05-04-2013, 08:24 AM Thread Starter
tonydotigr
Thanks all, gonna start with the bolt/bolt sleeves with the aftermarket shocks because it started shortly after those were installed.
post #9 of 9 Old 05-04-2013, 11:07 AM
ZB_WJ
Originally Posted by wj_runner99
had the same issue! All i did was back the bolt out a little and put some thread locker on em'. Then used a breaker bar and tightened the hell out of them. That was a tear ago and haven't had an issue since.
x2
I think we all just need a beer. :cheers2: (courtesy of ChrisHager)
This forum is a double edge blade, it's saved me thousands in repairs and cost me thousands in mods
ZB_WJ is offline
