noise from front end WJ - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > noise from front end WJ
Bds fox ipf 2.0 racing series shocks now available at rock20 Ton Press Brake DIY Builder Kit @ Swag Off RoadRough Country Lift Kits and Parts!
Unread 08-24-2012, 08:06 PM   #1
bigingwest
Wj noise from front end WJ
Ok so I wanna run this buy you guys. I went on a light 4x4 trip and after I noticed a weird noise from the front end it sounded like I was running over those rumble strip on the side of the highway only on decel or coasting at speeds of around 70kph + but I wasnt running over them. It continued to get worse over minor driving for the next two days so i removed the front drive shaft and the sound seems to be gone or so faint you would have to strain to hear it. I am thinking Pinion bearing what do you guys think?
bigingwest is offline   Reply With Quote
Unread 08-24-2012, 10:46 PM   #2
rcwj04
rcwj04's Avatar
If you have the 242 it was probably still in 4wd part time
You forget that most members here don't own a crystal ball to tell you exactly what your problem is, specially with bad pictures that don't say/show much of anything... -Jacko84
RIP Ratmonkey (Tyler)
2004 WJ 107k
2" BDS coils & Billy 5100's, Addco rear swaybar with energy bushings(planning on getting front also)
K&N FIPK, glasspack, plasti-dipped badges, 17" moabs, HID's, 245/65/17 Cooper Discover AT3, Rola rack, Fawkes stand alone shackle tabs
rcwj04 is offline   Reply With Quote
Unread 08-25-2012, 12:12 AM   #3
bigingwest
lol yah but I have the qudra track 2 not 242
Unread 08-25-2012, 05:36 AM   #4
asatxj
If you pulled the front DS and the problem went away the problem is your front drive shaft. If you have a rezeppa joint, it's likely the problem.
Jeep Fleet Maintenance Director
'00 WJ, son's Jeep,'01 WJ mine, '04 TJ, brother's Jeep,00 WJ daughter's
Maintain your stuff so you don't have to fix your junk
ASAT= All Season All Terrain
asatxj is offline   Reply With Quote
Unread 08-25-2012, 12:57 PM   #5
bigingwest
nope I have the conventional double cardon I thought maybe with the load of the driveshaft off the bearing it might have quite down or stopped making noise. Am I completely out to lunch with that thought?
Unread 08-25-2012, 04:10 PM   #6
Cdy291
I would go ahead and replace the front wheel hubs if you haven't already. You can do like me and get a pair off Ebay for what Autozone wants for 1.
Cdy291 is offline   Reply With Quote
Unread 08-25-2012, 04:32 PM   #7
TastykakeWJ
do you have any play in the steering wheel when you turn??? or is it just over 70???? my .02 say wheel bearing, or hub like Cdy291. or do a complete lube order ( grease the front and see if that may help at all sometimes the smallest piece of dirt can do the damndest things) or maybe you lost a wheel weight
1988 331 hp vw GTI 16v -RIP
1992 556 hp eg hatch Civic-RIP
I'm used to being as low as humanly possible, with lots of tuck, clean and mean son.
I also take speedbumps like a Boss
TastykakeWJ is offline   Reply With Quote
Unread 08-25-2012, 05:00 PM   #8
billzcat1
Chicken in a Turkey Suit
2003 WJ
Sounds like a bad U-joint to me.
billzcat1 is online now   Reply With Quote
Unread 08-25-2012, 05:26 PM   #9
bigingwest
Yah i am leaning towards a bad u joint cuz the sound is gone with axle removed
Unread 08-25-2012, 05:28 PM   #10
bigingwest
*driveshaft not axle lol
