No speedo or tach after brake job? - JeepForum.com
post #1 of 6 Old 03-16-2010, 02:10 PM Thread Starter
PsyJeep
Hey guys I did a front brake job with my buddys the other day on my 99' JGC Limited with a 4.7 in it. We finished up and I fired it up and I have no speedo or tach. No sensors were bumped that im aware of.
Any idea what this could be?
PsyJeep is offline
post #2 of 6 Old 03-17-2010, 09:31 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
well the tach is odd but the speedo gets info from the abs computer.
ratmonkey is offline
post #3 of 6 Old 03-17-2010, 12:13 PM
TrevorJeepin
you damaged abs senosrs check the wire
TrevorJeepin is offline
post #4 of 6 Old 03-22-2010, 10:41 AM Thread Starter
PsyJeep
Where is the wire located?
1999 WJ Limited 4.7 Quadradrive
A few goodies
PsyJeep is offline
post #5 of 6 Old 03-22-2010, 01:26 PM
TrevorJeepin
its located on the back of the front steering knuckle next to the hub assembly bolts. the wire runs under the upper ball joints then attaches to the frame where the brake lines attach check this stretch of cable for nics cuts and what ever else you might see on both sides of the jeep
post #6 of 6 Old 03-22-2010, 01:28 PM
TrevorJeepin
also try resetting your computer (take the negative off the battery for 15 minutes)
Lost speedo/tach madrabbitt ZJ Grand Cherokee Forum 5 02-28-2010 05:38 PM
speedo and tach stoped working raygoodson2006 ZJ Grand Cherokee Forum 2 12-07-2008 08:56 AM
speedo and tach quit 2000stocker ZJ Grand Cherokee Forum 10 12-02-2008 06:32 PM
Speedo and Tach not working jnkarrik ZJ Grand Cherokee Forum 1 03-16-2006 08:13 PM
Speedo and tach sleeping jmanimal ZJ Grand Cherokee Forum 2 04-04-2004 09:36 PM
