No spark wj - JeepForum.com
post #1 of 8 Old 08-31-2017, 08:34 PM Thread Starter
njc2rn
No spark wj
Hi! I have a 2001 WJ with a replaced 4.7l engine with about 25k miles on it. I replaced the engine myself about 2 years ago. Has a new tps and crank position sensor.
Anyways, a few days ago upon hard acceleration felt a knock in drive train and jeep died. Now it will turn over but not start. Fuel rail is pressurized but doesn't seem to have spark, pulled number 1 coil and tested with plug in and no spark. I get no error codes.
I'm stumped. Any ideas?
Ecu??
njc2rn is offline
post #2 of 8 Old 09-01-2017, 02:40 PM Thread Starter
njc2rn
Okay finally got a code p0340.. which I replaced when I out in the engine.. replaced camshaft position sensor again today.. still same code and no start.
Slipped timing chain?
njc2rn is offline
post #3 of 8 Old 09-13-2017, 04:15 PM Thread Starter
njc2rn
Thought I'd bumpo this as I'm getting nowhere.. Any one have any ideas?
njc2rn is offline
post #4 of 8 Old 09-20-2017, 04:17 PM
flon_klar
When I've had similar issues before, it's been either the crankshaft position sensor or the auto shut down relay.
flon_klar is offline
post #5 of 8 Old 09-21-2017, 08:26 PM
jclaudii
Could be those new cam or crank sensors. I have had to go through a few to get one that works reliably sometimes. Make sure grounds are all good. Are dash gages acting weird?
jclaudii is offline
post #6 of 8 Old 09-23-2017, 12:07 AM
rep-tile
Cash 4 Clunkers Survivor
rep-tile's Avatar
The camshaft positions sensor has no effect on spark, its only purpose is to sync the fuel injectors. A bad crankshaft position sensor on the other hand would give you no spark. You want an OEM replacement only. Could be a bad ECU too, potentially.
04 WJ 4.0 - Avital 4103, DB-ALL
91 XJ 4.0 - Avital 4103, Stage-2 aFe intake system, BBK high flow Throttle Body, Jones Exhaust A3518M-5
rep-tile is offline
post #7 of 8 Old 09-24-2017, 09:19 AM Thread Starter
njc2rn
I am still gettiing the p0340 camshaft position sensor code, which I changed and still that code. Would a slipped timing chain give me that code and now spark? It was a sudden failure.... so weird. I will try changing iif t again with an OEM.. as well as crank position sensor.
Any easy way to tell if timing chain slipped? Besides compression.. (I need to buy a tester)
njc2rn is offline
post #8 of 8 Old 09-25-2017, 09:29 AM
86cj74.2L
86cj74.2L's Avatar
I am still gettiing the p0340 camshaft position sensor code, which I changed and still that code. Would a slipped timing chain give me that code and now spark? It was a sudden failure.... so weird. I will try changing iif t again with an OEM.. as well as crank position sensor. Any easy way to tell if timing chain slipped? Besides compression.. (I need to buy a tester)
that "no cam signal at PCM could be bad wiring, bad sensor, something wrong with the tone ring on the cam, or PCM itself.
The connector is on the replacement sensor correctly and securely with the red tab pushed over to lock it in place?
Checking the wires for continuity between the sensor connector and the PCM harness plug would be next.
86cj74.2L is offline
