No heat.... or very little - JeepForum.com
post #1 of 6 Old 12-22-2013, 11:33 AM Thread Starter
Kevinyj95
Barely any heat at all wont even defrost the window. Kinda sucks when you have to get out and scrape your window every two mins in the freezing rain.
00 4.7. new rad, water pump , fan clutch and thermostat 195*. It did this last year before the new parts as well. heat core has good flow flushed it twice. NO leaks no air. The heat is warm hot when its warmer like fall. Now that its winter were freezing again. blows air good just only slightly warm. Thanks for any help or tips. Im thinking heater core but it has good flow when I hook the hose to it and flush it.
Kevinyj95 is offline
post #2 of 6 Old 12-22-2013, 12:11 PM
creepingdeath94
Maybe blend doors not making a good seal between heater core/evaporator side? If the foam internally has come apart it could just be inefficient for how cold it is.
creepingdeath94 is offline
post #3 of 6 Old 12-22-2013, 12:41 PM
LowLyfe
Both sides blowing cold air?
02' Jeep WJ Limited Edition - Stock height on Hankook Dynapro ATM RF10's 235/65/17
LowLyfe is offline
post #4 of 6 Old 12-22-2013, 02:04 PM Thread Starter
Kevinyj95
yes its the same everywhere.
post #5 of 6 Old 12-22-2013, 02:44 PM
86cj74.2L
86cj74.2L's Avatar
If you are not overheating and your engine temps are always normal its time to look at your heater controls.
You could loosen a clamp on the coolant lines going to the heater core and make sure coolant comes out.
Doing a few 3/4 throttle accelerations to 60 should push any air trapped in the heater core back into the block where it can get dumped into the rad.
86cj74.2L is offline
post #6 of 6 Old 12-22-2013, 03:09 PM
abock33
My heat was the same way until Friday. Bit the bullet and put a new heater core in it. I had good flow as well. When I pulled the old one it weighed three times as much as the new one. It turns out it was most of the way clogged but i couldn't tell cause the flow through the clear tubes was hiding the issue. It's nice to have heat. If you can set aside a day and replace it as we'll as your a/c evap core since your in there.
"Of course he likes your idea. When one retard on the short bus licks the window, the others think it's a great idea and start licking like crazy!" Rob99
abock33 is offline
