no heat till you drive - JeepForum.com
post #1 of 13 Old 02-07-2014, 10:08 AM Thread Starter
twowlcruzer
2009 JK Wrangler
Wj no heat till you drive
ok.. this is odd. I can start my jeep in the drive way and let it idle or just start and take off.. but until its been running awhile I cant get any heat at idle. it can be at temperature just idling after start up in the driveway. but no heat till I get the rpms up and or drive it. then all the sudden I have heat at idle after that.. its only right after its started.. and been running at temp for a lil while.. very strange.. no water in the oil. no loss of coolant.. the blowers speeds are all there.. modes all work.. so.. who knows..
twowlcruzer is offline
post #2 of 13 Old 02-07-2014, 11:11 AM
ChrisHager
Administrator
ChrisHager's Avatar
I wonder if you have an air bubble that is getting trapped in your heater core...
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #3 of 13 Old 02-08-2014, 01:34 PM
Ep3tch
Did you try a new thermostat?
Ep3tch is offline
post #4 of 13 Old 02-09-2014, 05:30 AM
2000_limited
I noticed mine will never get up to running temp at just idle. I have let it run in my driveway for 30 mins and it won't blow hot air. but as soon as I drive and get down the road 1/4 mile, I got heat.
2000_limited is offline
post #5 of 13 Old 02-09-2014, 06:13 AM
-OIIIIIIIO-01
Fab skills required....
-OIIIIIIIO-01's Avatar
Do you have the electric dual temp unit? Sometimes it seems like the heat coming out needs to be a certain temp before blowing out?
A trick I do is turn it up to high, then low, then back to high. It starts blowing cold air till the vehicle warms up.
91 YJ 4.0/AX15/231J
HP D30 /Akebono's /1 Ton GM Crossover Steering
Ford 8.8/ Trac loc LSD
35x12.5x16 Nitto Trail Grapplers
Walbro255 MetalCloaks
-OIIIIIIIO-01 is online now
post #6 of 13 Old 02-09-2014, 07:02 AM
imaguy3
That's how the dual climate is designed... It won't let the blower fan engage until the heat comes up to a certain temp.
As far as changing your thermostat that's not your problem.
EvilEagle - "Imaguy3 just made everyone in this thread his *****."
imaguy3 is offline
post #7 of 13 Old 02-10-2014, 06:17 AM Thread Starter
twowlcruzer
2009 JK Wrangler
its a standard controller.. and thermostat is working fine when monitoring the temp guage.. im thinking it may be the controller.. ?!?!?!?
post #8 of 13 Old 02-10-2014, 07:13 AM
JustStew
Have the dual zone and mine would do the same thing....blower would start and everything but it wouldn't go hot till about a mile down the road. I bled the system and it fixed it
JustStew is offline
post #9 of 13 Old 02-10-2014, 10:01 AM
thunderdan2000
Mine is doing the same thing. I chalked it up to extremely cold temps here but as it has warmed up (and I use that term loosely) it hasn't got much better. I have been smelling antifreeze lately but I am not losing any. I was think a bad heater core but I don't have any signs of that and It heats up fine once drive. I will have to look into bleeding the system.
thunderdan2000 is offline
post #10 of 13 Old 02-10-2014, 10:09 AM
rdkendrick
2003 WJ
I think you might have a clogged heater core. The pressure of driving it is pushing the hotter water into the core when you are driving, but with the pressure only at idle, it's not enough. Did you try flushing your heater core? Perhaps with the chemical kind that dissolves calcium build-up?
Sent from my iPad using electrons
rdkendrick is offline
post #11 of 13 Old 02-10-2014, 10:15 AM
wj-jeepdrew
Yea I agree. Sounds like you have a clog in the system.
wj-jeepdrew is offline
post #12 of 13 Old 02-10-2014, 11:40 AM
WJChris
WJChris's Avatar
or a faulty water pump. Pull the pump and check the condition of the timing chain cover and the water channels under the water pump.
WJChris is offline
post #13 of 13 Old 02-10-2014, 04:48 PM
rdkendrick
2003 WJ
Doh! Forgot about the water pump!
