no fuel to engine - JeepForum.com
post #1 of 43 Old 06-25-2014, 04:47 PM Thread Starter
2002jeepIN
no fuel to engine
My 2002 jeep grand cherokee 4.7L is not getting fuel to the engine. It has a new fuel pump and filter. I checked the fuses all good. What else am I missing that may csuse this. Thanks
2002jeepIN is offline
post #2 of 43 Old 06-25-2014, 05:07 PM
99WJ539918
You checked the relay? Are you not getting any fuel to the rail?
Build Thread
99WJ539918 is offline
post #3 of 43 Old 06-26-2014, 08:27 AM
ChrisHager
Administrator
ChrisHager's Avatar
Can you hear the pump kick on when you turn the key to 'run'?
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #4 of 43 Old 06-26-2014, 10:24 AM
Jeeples
Jeeples's Avatar
Getting spark? Assuming all else is good (relay) then I would suspect either a cam or crank position sensor.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #5 of 43 Old 06-26-2014, 11:56 AM
86cj74.2L
86cj74.2L's Avatar
The ASD relay feeds power to fuel pump and injectors.
86cj74.2L is offline
post #6 of 43 Old 06-29-2014, 12:17 PM
mrtoner
Wj
I had a similar issue (starving for gas). And thought it was a clogged filter. Everything else seemed ok. When I crawled under to get to the filter, I noticed that the line out from the filter was kinked, and a nearby wire harness was knocked out of its retaining hook. I do all the work on it, so I know it was not there before. I guess when I drove over some gravel one rock flung the right way and knocked the harness out and hit the gas line. Spliced it with fuel injection grade hose and works fine.
mrtoner is offline
post #7 of 43 Old 06-29-2014, 10:30 PM Thread Starter
2002jeepIN
No fuelmis not going to the rail and I cant hear the pump come on. I will try the relay replacement.
post #8 of 43 Old 06-30-2014, 08:05 AM
99WJ539918
Keep us updated... You can just switch your starter relay with your fuel pump relay and see if the pump primes and then if the Jeep cranks. If the fuel pump primes and your Jeep doesn't crank anymore then you know you have a bad relay, at least.
Build Thread
post #9 of 43 Old 06-30-2014, 12:19 PM
86cj74.2L
86cj74.2L's Avatar
Don't forget ASD relay.
post #10 of 43 Old 07-01-2014, 05:05 AM Thread Starter
2002jeepIN
I tested,the relays and they are good. I even switched them out and got nothing. I can get the engine to turn over just no fuel going to the rail.
post #11 of 43 Old 07-01-2014, 05:14 AM
86cj74.2L
86cj74.2L's Avatar
Is your ASD relay energized at ignition on?
post #12 of 43 Old 07-01-2014, 06:35 AM
kfxnando
This could be a stupid idea
however
when the fuel pump was changed, did the fuel pump get plugged in
or/and
did it get plugged in properly
good luck
http://s538.photobucket.com/user/kfxnando/library/?sort=3&page=1
kfxnando is offline
post #13 of 43 Old 07-02-2014, 04:37 AM Thread Starter
2002jeepIN
Im going to double check the plug but I remember plugging it in until I heard it click. Also going to replace the ASD relay. I will let you all know how it went.
post #14 of 43 Old 07-02-2014, 05:10 AM
99WJ539918
Make sure the fuel pump is getting power as well.
Build Thread
post #15 of 43 Old 07-02-2014, 06:21 AM
Double E
Double E's Avatar
At the filter, if the connections are not tight, they can do the no-fuel delivery issue,...I made this mistake.
Next question, will it run with starting fluid sprayed down the intake? (Just to be certain it WILL run.)
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is online now
