no defrost - JeepForum.com
post #1 of 7 Old 09-29-2010, 01:21 PM Thread Starter
1999_GC
Wj no defrost
I have a 1999 Grand Cherokee Laredo with the 4.7 V8. When I put the defrost on, air only comes out of the vents near the floor. All of the other vents work fine. Has anyone else seen this problem? Does anyone have any suggestions on how to fix this? Winter is coming and I need the defroster.
Thanks.
1999_GC is offline
post #2 of 7 Old 10-01-2010, 07:56 AM Thread Starter
1999_GC
No one has ever had this problem? Anyone??? Come on guys.... help me out here.
1999_GC is offline
post #3 of 7 Old 10-01-2010, 12:21 PM
seu83
Not sure if this is similar or if will even help but my friend has an xj with what sounds like the same issue. He has no defrost but the other vents work fine. But if he's going down the road and punches it enough to where it down shifts and he's running at a higher rpm the defrost kicks right on. Turns out it was a vacume leak.
seu83 is offline
post #4 of 7 Old 10-01-2010, 01:21 PM
Blue04WJ
check the vacuum hoses. Also the servo under the battery. there's quite bit of info on here about that problem is ya search.
Blue04WJ is offline
post #5 of 7 Old 10-04-2010, 05:04 PM Thread Starter
1999_GC
The attached diagram shows the vacuum for the manual a/c controls. If I am reading this right, the defrost mode is normally open The other vents work properly,
I checked the vacuum readings at the controls and had a vacuum reading of 8 Hg at every setting which leads me to believe I do not have a vacuum issue.
Could the actuator be jammed?
1999_GC is offline
post #6 of 7 Old 10-04-2010, 07:47 PM
kadetklapp
1997 XJ Cherokee
You say only the floor vents work and then you say all the other vents work fine. Which is it? If it will not "switch" from floor to another setting (ie defrost, panel, etc) then it's likely to be a disconnected vacuum line. Easy fix. Check the intake for disconnected lines. Mine did this last winter. Cruise control wouldn't work either.
**1997 Jeep Cherokee SE**
Former Police Car assigned to 54-26, RIP.
kadetklapp is offline
post #7 of 7 Old 10-08-2010, 11:18 AM Thread Starter
1999_GC
Well I solved the problem. The actuator for the defrost door was broken. Here is a photo of the new part that I got from a junk yard today. Pretty easy fix.
1999_GC is offline
HVAC: a/c works only on defrost JeeplessInGB WJ Grand Cherokee Forum 6 07-24-2011 01:53 PM
AC/Heat/Defrost Issues Sintini WJ Grand Cherokee Forum 3 09-16-2010 11:44 PM
no air in defrost modes jeep n00b WJ Grand Cherokee Forum 1 09-16-2010 01:10 PM
Air Conditioning only works on defrost mode... Lsportline43 WJ Grand Cherokee Forum 6 08-08-2007 07:23 PM
AC blowing out defrost only??? 10achik WJ Grand Cherokee Forum 2 05-27-2004 03:52 PM
