No compression in ANY cylinder? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > No compression in ANY cylinder?
Steering and more from Ruffstuff!The Ruffstuff 14 Bolt Complete Swap Kit!Ruffstuff Axle Simple Swap Kit!
Unread 09-16-2010, 07:18 PM   #1
manofmany
On a 99 4.7 that was overheated and now will not start. It turns over but is VERY weak/slow as if the battery is dead. Tried charging the battery and jumping it but that made no difference. Doesn't even begin to fire.
Did a dry compression test on each cylinder and they all showed. I verified the tester is good on my other vehicle. Any ideas?
1998 Cherokee 4.0L
1999 Grand Cherokee Limited 4.7L
manofmany is offline   Reply With Quote
Unread 09-16-2010, 07:22 PM   #2
cherokeekid58
Hmmmmm...... Seriously a wild guess here but my first thought is fried the rings? Or valves are stuck open somehow
[QUOTE=sonoran_Tj
"If we collect data long enough, we may discover the root psychological cause for the "jeep thing".
So far it seems correlated to OCD and the need to look at one's poop."
cherokeekid58 is offline   Reply With Quote
Unread 09-16-2010, 07:22 PM   #3
FirefightinWJ
Sounds like a blown head gasket...hard to imagine you toasted both of them at once, but its possible.
LET'S GO PSU
04 WJ Laredo I6
5.5" IRO CP
32" BFG M/Ts on JK 17's
-Devin
FirefightinWJ is offline   Reply With Quote
Unread 09-16-2010, 07:34 PM   #4
manofmany
I've confirmed no coolant in the oil and vice versa.
If it is the valves, will the cam turn at all?
1998 Cherokee 4.0L
Unread 09-16-2010, 08:18 PM   #5
narnwv
narnwv's Avatar
Intake manifold gasket?
~Aaron
NarnWVs Build Thread
2000WJ 4.7 247->242 swap,
Rough Country X-series 4",
K&N, Flowmaster Super 44,
JK Moabs+32" BFG KM M/Ts, Addco rear
custom4x4fabrication rear bumper
Hitch-Mount Tire carrier for sale
Originally Posted by jeep04 View Post
I just drive mine with a helmet on (just in case)
narnwv is offline   Reply With Quote
Unread 09-16-2010, 08:25 PM   #6
LarryGrant
Try draining the oil and look for metalic parts. I find it hard to believe all cylinders have no compression. inless ALL valves got bent not allowing them to seat. could be a head gasket but still both sides on ALL cylinders? Good luck and let us know the outcome.
LarryGrant is offline   Reply With Quote
Unread 09-16-2010, 08:34 PM   #7
manofmany
Will be seeing what I can find tomorrow.
One last question - Shouldn't it still turn over quickly regardless of whats wrong? It turns over VERY slowly.
1998 Cherokee 4.0L
Unread 09-16-2010, 08:37 PM   #8
LarryGrant
Depending on the problem. broke a cam, broke rings that a grinding into the cylinders...but I still think that is unlikely. could be the starter itself as it could have hung up causing the overheating problem to begin with.
Unread 09-16-2010, 08:40 PM   #9
Chris00WJ
Shoot a few drops of oil in each spark plug hole and try again. It will help it turn over a little better and should give you a bit of an idea on compression issues. Its possible you arent turning it over enough to get any compression reading on the gauge.
Chris00WJ is offline   Reply With Quote
Unread 09-16-2010, 08:42 PM   #10
LarryGrant
should turn it over 4 times for the correct compression. make sure the gauge is seated proper in the hole also.
Unread 09-17-2010, 04:52 AM   #11
cherokeekid58
Well my 4.0l cranked slow when it had five gallons of coolent and oil, in the oil pan lol. But I doubt that's what your problem is. The cam can still turn even if the valves are bent, because it will push the valves open but then they won't close again. So I would consider checking the valves, pushrods, loggers, cam, and what not.
[QUOTE=sonoran_Tj
Unread 09-17-2010, 08:32 AM   #12
LarryGrant
thought about this also..spun bearing binding on the crank. How many miles on the motor?
Unread 09-17-2010, 10:29 AM   #13
manofmany
147k miles
Got the valve covers off. The valves are operating correctly. The chains are intact and look to be in great shape.
Got the battery tested and it tested fine. It has spark. Seems to be getting fuel. What next? Pull the starter and have it tested? Pull the heads?
1998 Cherokee 4.0L
Unread 09-17-2010, 10:56 AM   #14
Double E
2000 Laredo V8
Double E's Avatar
Can you turn it over with your hand over the S. Plug tube holes? I'd want a "self diagnosis" before I tore off the head.
How about a bore scope? Borrow one? I would really want to see before tearing into it...
Ok...maybe pull starter too.
2000 Laredo 4.7L Selec-Trac. 161K miles, Leather, 245 tires, tow package, crappy CD changer, full size spare, roof cross-rails & sunroof.
Changes & fixes: Rear Addco sway bar & greasble bushings, upgraded headlights, upgraded tail lights, new hood struts (replaced 2X), new rear hatchglass struts, new radiator (replaced 3X), new oil pressure sending unit (replaced 2X), 2 new speed sensors, 2 new door lock actuators, new ignition key cylinder, chrome front tow hooks, Mobil 1 Synthetic 5/30, Purolator Pure One oil filter, EBC slotted & dimpled rotors, EBC Greenstuff pads, new front shocks (replaced 3X), new rear shocks (replaced 2X),
new IRO steering stabilizer, new timing chain cover, new water pump, thermostat, new thermostat housing, new high pressure power steering hose, Michelin-X radials, new sunroof assembly, new single-piece lug nuts, new exhaust manifold studs & gasket on driver's side. Jeepforum.com sticker, Visit cobaltboatsforum.com when you can!
Double E is offline   Reply With Quote
Unread 09-17-2010, 12:16 PM   #15
LarryGrant
Id test the starter next. Air,fuel,spark. one is missing. Did you find the cause of the overheating?
