Night time brake lights not working - JeepForum.com
post #1 of 8 Old 02-06-2014, 03:18 PM Thread Starter
Blakehenry96
For some reason my brake lights don't work. They work when I don't have headlights on, but when I turn my headlights on they don't come on as the running lights, but if I push the brake they work. I replaced the brake switch fuse and still nothing
Blakehenry96 is offline
post #2 of 8 Old 02-06-2014, 03:21 PM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
Sounds like you have bad housings, very common on the WJ. You can get new ones on E-Bay for about $35 each.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #3 of 8 Old 02-06-2014, 03:25 PM Thread Starter
Blakehenry96
it's not because I don't have the stock tail lights, I have the spyder taillights and when it went out when I was put a led in the side post
post #4 of 8 Old 02-06-2014, 03:27 PM
Son-of-Beast
I recently put the CG LED Taillights on my WJ and found that the aftermarket connector for the taillight housing did not initially seat completely with the stock connector, then when I made it fit, it pushed a pin into the stock side connector. Pulled that out and carefully connected them and no issue now. Check the connector on both sides and look for bent/pushed in pins.
'Son-of-Beast' - '02 WJ Limited, 4.7, 545RFE 5-spd Auto, Quadra-Drive, KOR 2.5" BB, Rancho RS5000's, Firestone Destination AT 265/70R17's, Flowmaster DeltaFlow 40, KMA/TAG armor, JK Fuel Door, Spyder CCFL Halo Projectors, LED Taillights, LED Interior Lights - Build Thread:
Son-of-Beast is offline
post #5 of 8 Old 02-06-2014, 03:29 PM Thread Starter
Blakehenry96
I'll check that but it was working when I plugged them back up
post #6 of 8 Old 02-06-2014, 03:31 PM
Son-of-Beast
FWIW, mine worked fine for a day or two, then acted up when I pulled them back out to replace the cheap incandescent bulbs they shipped with better incandescent bulbs for the reverse and turn signal.
It could also be improper resistance with LED bulbs if the housings were set up for incandescent bulbs - if you have the old bulbs try putting them back in and see if that is it.
post #7 of 8 Old 02-06-2014, 03:57 PM Thread Starter
Blakehenry96
FWIW, mine worked fine for a day or two, then acted up when I pulled them back out to replace the cheap incandescent bulbs they shipped with better incandescent bulbs for the reverse and turn signal. It could also be improper resistance with LED bulbs if the housings were set up for incandescent bulbs - if you have the old bulbs try putting them back in and see if that is it.
I did and unplugged to see if I had bad prongs and they are good
post #8 of 8 Old 02-06-2014, 04:02 PM
rdkendrick
2003 WJ
Just to let you know, that's only for turn signals. The resistance is for the correct capacitor discharge in the flasher module. That's why, when there's no resistor with the LED, or a bad bulb, it hyper-flashes.
Sent from my iPad using my fingers
rdkendrick is offline
