new to WJs. 6" lift.. no uca? - JeepForum.com
post #1 of 17 Old 04-25-2013, 06:42 PM Thread Starter
AKjeepin
Hi guys, names devin, new to the forum and to WJs. I just picked up a 2001 WJ with a 6" rock krawler LA lift for $1500! Cant really beat that huh? All it needs to drive is a new cv axle.. so I thought... I was under looking around and noticed that I have no passenger side UCA.. had anybody ever seen this? Normal? Im totally new to wjs and lifts (I also have a 03 kj so im not totally new to jeeps) thanks for the help in advance
AKjeepin is offline
post #2 of 17 Old 04-25-2013, 06:45 PM
wvracer821
wvracer821's Avatar
im not sure how the rock krawler is set up but iron rock off road uses one radius arm and one single lower arm up front. im sure somebody will be able to answer this quickly
DD: 2014 RAM 3500 Megacab Larmie 6.7L Cummins
Junk: 2000 WJ, 4.0L
Build Thread:
wvracer821 is offline
post #3 of 17 Old 04-25-2013, 06:50 PM
adavis39
i believe at one point, rock krawler made a true 3-link for the WJ. I may be wrong. but its probably just like the IRO set up. Its a radius arm on thew driver side and a single lower control arm on the pass side.....so yes, its fine
2002 WJ Limited 4.7: 6" Clayton REALLY long arms....yep, they are longer than yours SOLD : (
1998 Platinum 5.9 DD
2007 WK Overland 5.7 wifes DD
TNJEEPS.COM
BUILD:
"In a world that he did not create, but he will go through it as if it is his own creation. Half man, half beast, whatever it is it is weird, it is ticked off and it calls itself Slash"
adavis39 is offline
post #4 of 17 Old 04-25-2013, 07:18 PM
duranged
I have a RK lift. It is a true 3 link. No radius arm. Passenger side only has a LCA.
2001 WJ Limited; 4.7L; 4.5" RK LA; 305:65:17 ProComp Xtreme AT; 231 HD w/ SS SYE; KOR sliders; ARB front w/Warn and in-cab controls; Custom4x4Fab rear; Dual Battery via 12voltguy.
duranged is offline
post #5 of 17 Old 04-25-2013, 07:30 PM
skain8
skain8's Avatar
Consider yourself lucky. The 3 link (assuming RK designed it properly) is far superior to the radius design. Too bad no one fabs a 3 link for the wj anymore.... for now.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is online now
post #6 of 17 Old 04-25-2013, 07:48 PM
85IrocZ-28
I have the RK there link up front. It flexes like crazy, great setup. The joints are loud though, I am running Johnny joints now.
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY ---
85IrocZ-28 is offline
post #7 of 17 Old 04-25-2013, 07:52 PM
jeep04
As already said yes Rock Krawler does not use the upper on the passenger side, i believe that's the same lift a member on here has (85Irocz-28) . He has some awesome flex pics in his build thread over in general discussion if you want to see what to expect.
edit...He beat me to it
04 Jeep wj Limited 4.7 <> 6.5" Iron Rock long arms front & Adjustable lowers on rear <> Bilstein 5100's <> 285/70r17 Goodyear Duratracs <> M/T black classic lock wheels <> Addco swaybars <> Superchips 3875 <> Magnaflow Stainless exhaust <> 2 Kicker comp 12's <> Kenwood head unit.
jeep04 is offline
post #8 of 17 Old 04-25-2013, 08:20 PM Thread Starter
AKjeepin
Wow you guys seriously just made my day. Thank you all so much for the speedy response. Im excited to learn more about these jeeps and i CANNOT wait to get this baby on some trails. I live up here in Fairbanks Alaska so she will see some good use
(Hoods popped in the pic)
AKjeepin is offline
post #9 of 17 Old 04-25-2013, 08:23 PM
wvracer821
wvracer821's Avatar
any pics of the RK setup? I'm looking to build my own arms this summer and need some ideas.
Junk: 2000 WJ, 4.0L
Build Thread:
post #10 of 17 Old 04-25-2013, 08:28 PM Thread Starter
AKjeepin
I will take some pics tomorrow when I get back to work and post some
AKjeepin is offline
post #11 of 17 Old 04-25-2013, 10:29 PM
wvracer821
wvracer821's Avatar
I'm really interested in the upper link where it mounts to the body. im considering doing a real 3 link rather than a radius setup. ive been reading some stuff about suspension design over on pirate.
Junk: 2000 WJ, 4.0L
Build Thread:
post #12 of 17 Old 04-25-2013, 11:26 PM Thread Starter
AKjeepin
There's a bracket that bolts right in front of the long arm that it bolts too
AKjeepin is offline
post #13 of 17 Old 04-25-2013, 11:36 PM
duranged
this came from the install docs. pm me with your email if you want a copy.
duranged is offline
post #14 of 17 Old 04-25-2013, 11:43 PM
85IrocZ-28
EDIT: Mine are different that the one above, two piece instead of one piece. That design above is better IMO. The RK kit when through a few generations on the design.
I took some pics for a friend a few years back. Just look at the arms direction to orient yourself. The lower arm bolts to the bottom of the unibody frame rail, the upper control arm bolts to the inside of the unibody frame rail, inside the frame and above the location of the lower arm, at the same distance from the axle:
Distance it is from the unibody rail:
The RK upper link uses a heim on the body side, here is a closeup:
post #15 of 17 Old 04-25-2013, 11:56 PM
85IrocZ-28
This one shows the plate on the outside of the unibody...the plates sandwich the body to hold the uca.
EDIT- Forgot to add the last pic, here it is:
