New Rad - JeepForum.com
post #1 of 12 Old 07-13-2013, 09:01 PM Thread Starter
SuperStew11
New Rad
Well it looks like my 2000 4.7 WJ needs a new Radiator, After driving it and its fully up to temp it starts leaking hardcore after I shut off like its relieving the pressure.
Any tips on what I'm looking at to replace it and picking up a new one?
Thanks
SuperStew11 is offline
post #2 of 12 Old 07-13-2013, 09:58 PM
Mp5ben
2005 WK
I just went down to my local O'Reillys and picked up a Murray's radiator for $150. Installed easily and haven't had any leaks for over a month. I'm happy
05 WK Limited, HEMI 5.7, QD II, OME HD, 255/75/17 Mud terrains
Mp5ben is offline
post #3 of 12 Old 07-14-2013, 05:18 AM Thread Starter
SuperStew11
Ok sweet my main concern was how tricky it is work the AC condenser on front of it.
I've replaced a Rad before on my old Dakota but it didn't have AC or anything to have to worry about getting in the way
post #4 of 12 Old 07-14-2013, 06:52 AM
Cebby
You don't have to disconnect the AC - there is enough movement in the lines to allow you to maneuver the old rad out and put the new in.
2000 WJ Laredo 4.0 4x4 Taupe Frost - Clayton LA Front/Rear | IRO 3" Springs + 3/4" KOR | Bilstein Shocks | JKS Discos/Trackbar/Draglink & Tierod | Dual KOR Stabs | Spidertrax Spacers | 265/70R17 Duratrac's on JK 17's | Black Magic Brakes w/Centric Rotors | Akebono Calipers | Griffin Rad | K&N Drop in | Magnaflow Cat & Muffler shorty setup | Diehard Platinum (Odyssey) | RB1-NAV-Sirius-Chg-iPod | OEM Tow Hooks F/R
Cebby is offline
post #5 of 12 Old 07-14-2013, 05:37 PM
Breze
I have a 4.0 L and grabbed a murray from OReilly's today... they suggested the universal fluid over the Zerox that Chrysler suggest.. which would you use? ... Did you take your's and get a power flush or did you flush it yourself.. if so did you use a radiator flush kit
Breze is offline
post #6 of 12 Old 07-14-2013, 06:01 PM
Mp5ben
2005 WK
I just used universal coolant for my 01, and while it's really easy to flush the system I didn't bother since I already replaced the rad when we bought the Jeep a little over a year ago
Mp5ben is offline
post #7 of 12 Old 07-14-2013, 06:16 PM
narnwv
narnwv's Avatar
Watch your temps. "universal" and Mopar HOAT (what you should be using) don't mix well.
Typing on phones sucks.
~Aaron
narnwv is offline
post #8 of 12 Old 07-14-2013, 09:15 PM
Mp5ben
2005 WK
I watch it closely all the time now out of habit. Always stays just under the middle mark. When we bought my Jeep it had the green universal, never bothered to put hoat in it, what's the difference?
Mp5ben is offline
post #9 of 12 Old 07-15-2013, 08:08 PM Thread Starter
SuperStew11
Just picked up my new Rad today, 199 bucks later :S So should be putting it in, in the next couple days. I'll try upload some pics as I go
post #10 of 12 Old 07-16-2013, 07:58 AM
Double E
Double E's Avatar
Use this write up....then add your own experience to this thread.
http://www.jeepforum.com/forum/f310/...7l-v8-1437295/
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #11 of 12 Old 07-16-2013, 08:36 AM
skain8
skain8's Avatar
Listen to Double E on this one. He is the zen master of WJ cooling issues.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #12 of 12 Old 07-16-2013, 04:14 PM Thread Starter
SuperStew11
That's an awesome right up, the only thing I don't know is how to bleed the system without the vehicle running. I've looked up bleeding coolant systems and they all say to idle the vehicle with the heat running
And his right up says not to start the vehicle until you have bled the system, have I missed something?
