New Member with Fuel Issue - Page 2 - JeepForum.com
post #16 of 66 Old 12-25-2012, 08:49 AM Thread Starter
TrenchMaker
Unable to fill, and site still crashes. Oh forget me manners MERRY CHRISTMAS!
TrenchMaker is offline
post #17 of 66 Old 12-25-2012, 08:52 AM Thread Starter
TrenchMaker
Unable to fill. I managed to get about 16 bucks in fuel in there before I got honked at. Also the link http://www.wjjeeps.com/tsb.htm works but clicking on the additional links for detailed info causes the web page to fail. But yes I was unable to put fuel in it. This is after the jeep spent a night outside in minus 15 degrees celcius weather. I almost forgot: "MERRY CHRISTMAS"
post #18 of 66 Old 12-26-2012, 05:39 AM
Duh
I havent had my wj tank out yet, is there an antisiphon valve? I just had a new 2013 rover come off the truck and wouldnt accept fuel. Turns out one of the venturi hoses inside was routed up against that valve, not letting it open. My tj doesnt have one, but never had reason to drop the wj tank
Duh is offline
post #19 of 66 Old 12-26-2012, 06:06 AM
cuttysark
Just read that you have NGK plugs in there... they are not platinum are they?
I suggest you replace with all champion copper.
cuttysark is offline
post #20 of 66 Old 12-26-2012, 01:21 PM Thread Starter
TrenchMaker
Whats the reason behind going with all Champion copper? Jeep runs great with the NGK.
post #21 of 66 Old 12-26-2012, 01:23 PM
cuttysark
Yeah i was just making sure they weren't platinum. I think ngk and champion are the only two recommended for the base v8, i know definitely not platinum though.
post #22 of 66 Old 12-27-2012, 11:03 PM Thread Starter
TrenchMaker
I fixed it! Fuel filter. After I changed it, I could refuel, it starts easy and now all I have to do is track fuel mileage. I looked around on the site about the plugs and the consensus is that the Bosch do not have as good a reputation in this application. The NGK is performing well and most say they have no issues. Most of the posts seem to rag on the Bosch product. Has anyone had an issue with NGK?
post #23 of 66 Old 12-31-2012, 02:04 PM Thread Starter
TrenchMaker
Problem is back. Fuel mileage was doing ok until a few days ago. I am at 130 km and that cost 1/2 tank of gas. Also it cranks like mad before catching and just now when I went to lunch after it cranked for a while to start the check engine light is on. I will have to pull the codes to see what the problem is. Has anyone else had this issue? Should I change the O2 sensors next? Or should I replace the fuel pump and get the new O rings? I wonder if the last owner just did not take care of this thing or if I got a lemon.
post #24 of 66 Old 12-31-2012, 06:53 PM
cuttysark
see which code popped.
post #25 of 66 Old 01-02-2013, 08:44 PM Thread Starter
TrenchMaker
P1494 leak detection pump pressure switch...WTF?
post #26 of 66 Old 01-03-2013, 04:31 AM
shockracer
What brand filter did you buy?
2001 WJ 60th anniversary edition 4.7 quadra-drive
5" hybrid lift, 265/70/17 Guard Dogs load E, bilsteins 5100's, addco sway bars, JKS front quick disco's, JKS adjustable track bar, KOR durometer track bar bushings, IRO crucial path front L.A.s, 1.25" Spidertrax spacers
Colorado Jeep Club Member #262
shockracer is offline
post #27 of 66 Old 01-03-2013, 08:39 PM Thread Starter
TrenchMaker
WIX filter. Not sure part number.
post #28 of 66 Old 01-03-2013, 08:54 PM Thread Starter
TrenchMaker
I wonder if it might be a tiny vacuum leak. Possible? I cant hear it though.
post #29 of 66 Old 01-03-2013, 09:34 PM
shockracer
I've heard of the AutoZone filters failing but not the WIX filters, that's why I asked.
post #30 of 66 Old 01-05-2013, 01:16 PM Thread Starter
TrenchMaker
After more research I will inspect the vac lines.
