New to me higher mileage WJ - Oil opinions? - JeepForum.com
post #1 of 20 Old 07-22-2014, 08:41 AM Thread Starter
AllTime4x4
New to me higher mileage WJ limited History - Oil opinions?
Hey guys,
First, I'm not trying to start a syn vs dyno oil debate, just looking for some opinions on what I should use for the jeep I just bought. I run synthetic in all of our families vehicles, so normally I wouldn't even think of running anything else. With that said, I just got a really good deal on an 04 Limited w/ 128k on the clock. It's had 6 different owners throughout it's life, and while it's in pretty good condition, I highly doubt it's been running synthetic for it's life. I had good luck switching a Chrysler van with the 3.3l to mobil 1 at 160k with no leaks, but for some reason I'm a bit wary of this vehicle. We at least owned the van since practically new, but this jeep has a history that's completely unknown.
Some Observations: It looks like there's a bit of "wet" near the bellhousing/engine connect. I haven't had a car that doesn't exhibit some minor leaking at the rear main seal and am not really worried. It's not even forming drips. No spots of any kind on the driveways in the last 5 days. I have no clue if it's using any oil yet. It was about half a quart low when I picked it up, so I topped it off with some Mobil 1 5w30 high mileage. Maybe it's just me but it seemed to actually quiet things down even further. (Wasn't loud to begin, engine sounds really good) Needless to say I don't trust fluids in a used car from anyone and will be changing the oil along with everything else ASAP as soon as I get it back from having the rear axle seals replaced.
I'm thinking that at best I'll run some sort of blend, but first I'm thinking I'll throwing some cheap wally dyno in with a bit of seafoam or MMO, idling it for 15-20 minutes then changing with a quality dyno or blend. Hopefully this will remove any sludge it has. I haven't pulled the valve covers, so I don't have an idea of the internal condition. At this point, it's just a guess based on listening that it's relatively clean.
It's got the base 4.7l, very little engine noise, sounds very good for it's age and mileage. I'll also work on getting an analysis done when I get the time.
Opinions appreciated - thanks!
AllTime4x4 is offline
post #2 of 20 Old 07-22-2014, 09:01 AM
BIGBADWOLF
128k is not high mileage. IMO dino 10-30. The more frequent oil changes with dino instead of long intervals with synthetic are a plus IMO.
BIGBADWOLF is offline
post #3 of 20 Old 07-22-2014, 10:07 AM Thread Starter
AllTime4x4
What is considered high mileage for these motors? And what about a syn HM with 3000-4000 OCI?
post #4 of 20 Old 07-22-2014, 11:28 AM
biffs
I'm running Rotella T in mine. Mechanic recco'd it, so did a ton of people on the forums. I have 285km on my 4.0l
Build thread:
sure why I can't make that a real link)
biffs is offline
post #5 of 20 Old 07-22-2014, 01:02 PM
99WJ539918
I'm running regular 10W-30 in mine and have been for six years, I'm at 260,000 miles. As long as you change it on time you'll be fine.
Build Thread
99WJ539918 is offline
post #6 of 20 Old 07-22-2014, 01:27 PM
ace4usmc
I'd avoid the stuff labeled high mileage if you don't have any leaks. I didn't have any leaks before running some high milage for 4 or 5 intervals then switched back to dino oil and suddenly started getting oil on my drive way. The dripping only got worse when I put in T5 synblend. (the 4.0 loved it and ran quieter ) I've read that the high milage formulas have conditioners for the seals that cause the to swell to stop leaks. But when you stop using the HM stuff the seals return to their normal size but may not seal as well causing leaks.
ace4usmc is offline
post #7 of 20 Old 07-22-2014, 01:37 PM
Double E
Double E's Avatar
Rotella is best for the 4.0. Not the 4.7 as the OP has. Use the recommended, good quality 5w/30 synthetic or blend with Purolator Gold filter and do them at 3000.
Just did mine last night.
To me, high mileage is 200K or more on either engine.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #8 of 20 Old 07-22-2014, 03:22 PM
str8shooter
Every 6 month,(<3000miles) with mobil 1/Mobil1 filter on my 4.7ho since new and it purrs like a kitten.Doing the same with the wifes 2012 but she hits 6000 in the 6 month interval without a problem.Full synthetic gets my vote!
Every time I look at my Jeep it cost me more money!
str8shooter is offline
post #9 of 20 Old 07-22-2014, 03:27 PM
Cleaner13
I run amsoil 5w30 diesel oil. This is their synthetic and it does not need to be changed for 25K miles or 1 year.... I also run the oversize filter as well. Its approximately $60 for an oil change, but you are only doing 1 per year.
$60 once or $30 several times a year, not to mention the added time to buy it, pick it up and change it 3-5X more...
I run the amsoil 5w20 in my wife's liberty and its the same thing 25K miles/1year Both engines take the same oversize oil filter as well.
2001 WJ Limited NV247 4.7
2008 KK Limited MP253 3.7
2008 WK Limited NV245 3.0 CRD
Cleaner13 is offline
post #10 of 20 Old 07-22-2014, 03:49 PM
alfaitalia
There is no way I would leave any oil, no matter how good it might be, in a wj for twenty five thousand miles. Even top quality oil won't know how good your filter is, how you drive (lots of stop/start getting moisture in you oil) or how many miles you have done. It also won't know you are pouring it in an engine that was designed in the dark ages with the sort off clearances and tolerances that had three thousand mile oil change intervals in mind! You can put good oil in her but stick to recommended oil change times.
Sent from the Dark Side using only the Force.
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #11 of 20 Old 07-22-2014, 04:25 PM Thread Starter
AllTime4x4
Ok - I'll add something I left out. I've gotten a few puffs of white smoke upon hot starts and acceleration after idling down a hill or whatnot. I suspect the valve seals are the culprit and not the o-rings as it does not smoke under acceleration. I'm thinking that the HM oil's seal conditioner could help those seals specifically to prevent any further burning. After a pretty short interval and hot start I saw a nice white puff today so I went to Wally World and bought some M1 5w-30 HM and the M1 filter.
Also, what's the number of the extended capacity filter? I did the same thing in my Discovery II.
post #12 of 20 Old 07-22-2014, 04:40 PM
Cleaner13
With all due respect your incorrect, we arent talking about the 4.0L, its the 4.7
Also the service interval for the 4.7L is 6000 miles not 3000. The 25K miles from the Amsoil oil is based on the same service interval of Service Interval A. If you are doing severe driving, dusty roads, low temps etc.. you would adjust to Service Interval B, which would bring you to 12,500 miles..
The filter is specifically designed for running 25K miles.
You obviously need to monitor it as you go to make sure you do not burn or leak oil etc.. the same stuff I would expect you to do regardless of oil...
Im not saying, oh put this oil in and dont bother checking it for 25K miles...
The thing is so many people will chime in and say "I would never keep oil in for 25K miles, thats blasphemy.."
I guess my question to those people would be, how many miles are on your Jeep? I have over 300K... So i guess the oil isnt that bad..
post #13 of 20 Old 07-22-2014, 04:46 PM
Cleaner13
The Fram part # is PH8A
If you are using Mobil 1 I believe its M301
Amsoil is EA015
post #14 of 20 Old 07-22-2014, 04:54 PM
JPugh
White smoke? That's not oil, its probably water.
JPugh is offline
post #15 of 20 Old 07-22-2014, 05:39 PM
03CUSEWJ
2003 WJ
Maxlife 4life!
03CUSEWJ is offline
