New Jeep Owner- Starting problem - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > New Jeep Owner- Starting problem
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineHMF Fabrication 50" Light Bar Mounts for CJ/YJ Made IDISCOUNT LOCKER and AXLE SHAFT Days Sales at Baseline 4x4
Unread 04-07-2011, 08:04 PM   #1
pote87
I just bought a 1999 grand cherokee with the 4.7 engine. A few times since ive owned it the engine would continually try to start but would never fully turn on. After coming back and trying later it started, the check engine is now on. Also I kept it running after I got it started I kept it parked and it started to shake very badly so I turned it off and back on then it was fine.
Any ideas??
pote87 is offline   Reply With Quote
Unread 04-07-2011, 08:11 PM   #2
HVACNY
Tomorrow morning go to an autozone or something similar and they should read the code for you.So at least you will know what your dealing with. Theres also a way by turning the key on and of 3 times to get the codes if you dont want to wait. Check out WJJeeps to decipher the code and your on your way. Welcome aboard..
HVACNY is offline   Reply With Quote
Unread 04-08-2011, 06:24 AM   #3
99JGCWJ
99JGCWJ's Avatar
Any ideas??
Sounds like CKP sensor to me.
Sent from my VM670 using JeepForum
SIX IN A ROW MAKES IT GO!!!
99JGCWJ is offline   Reply With Quote
Unread 04-08-2011, 10:06 AM   #4
pote87
I got 2 codes from the dash: P0320 and P1685
I am looking online for what they could be but having no luck
Unread 04-08-2011, 10:21 AM   #5
pote87
Ok so I found out that P0320 is for the CKP sensor you mentioned, is that an easy fix?
The other, P1685 is for SKIM Invalid Key, is this an easy fix?
Unread 04-08-2011, 11:13 AM   #6
99JGCWJ
99JGCWJ's Avatar
The crank position sensor was an easy fix on my I6. Hopefully someone with a V8 will chime in here. I'm not sure if it's in the same spot. I doubt it is. The skim key code might be more complicated. That's a securtiy feature which will also stop the Jeep from starting. If you change the CKP first make sure you buy dealer only sensors. Jeeps and aftermarket sensors don't play well together. They're a little more expensive and a lot less headache.
Unread 04-08-2011, 11:20 AM   #7
99JGCWJ
99JGCWJ's Avatar
Btw, you may want to check out wjjeeps.com It will be your go to site after a while. It has answers to almost every WJ question there is.
Unread 04-08-2011, 12:08 PM   #8
dayneseditz
Wj
Thank god u dont have a 4.0 the crank sensor is a real pain in the butt to change...It took me over 3 hr to do it and i had to have someone else to get the bolt out because my hands are to big...
dayneseditz is offline   Reply With Quote
Unread 04-08-2011, 01:54 PM   #9
99JGCWJ
99JGCWJ's Avatar
I had this cheap socket set that someone got me for Christmas. The set blows but it had this long flexible rubber extension. I used that and it worked great.
