new guy with rear spring question - JeepForum.com
post #1 of 17 Old 08-05-2011, 12:19 PM Thread Starter
cheezy
Hi, i'm new to the wj jeeps, and i've been doing some research around here about the rear coils sagging. i measured mine, and i'm the same distance from fender to center hub on front and back, 18". from what i've read, i should have 19" in the rear. that being said, which is the better route to go, replacing the rear springs, or just adding new isolators that are .75" per unit? price isn't that important, $125 for a set of moog springs, or $40 for the lifted isolators. i have new shocks installed, and need to replace the sway bar bushings. i'm not looking to lift for off road, just for light duty trails, and hauling trailers/cargo. my wj has 146,000mi, 4.0l 4x4. thanks!
cheezy is offline
post #2 of 17 Old 08-05-2011, 01:23 PM
gqmdl0617
If your looking for a small lift, try seeing if you can find some up country springs. They were factory on some models, and gave about an inch more all around IIRC.
You could also just replace the isolators, as they tend to sag over time.
Best bet would be to do both.
White 2000 Grand Cherokee Laredo: 2" Fat Bobs BDS Springs with Bilstein 5100's, Addco sway bar, Black on Black heated leather, full limited wood grain, RB1, Mopar Ipod kit, 1000w of Kicker bass, 500w of lighting, Gen III projectors/5000K HIDs, Smoked full LED tails, 100w Whelen PA/Electric Air Horn with speaker mounted behind grill, Interior LED upgrade, 120v AC in the front and the back, Midland CB, PR-106 digital trunking scanner, yada yada yada. Just another WJ
gqmdl0617 is offline
post #3 of 17 Old 08-05-2011, 01:29 PM
tbone1004
I'd replace the coil spring isolators before you do spacers or shocks. $100 for all 8 of them and that will likely get back the half inch you're missing
tbone1004 is offline
post #4 of 17 Old 08-05-2011, 04:59 PM
WJ04
18" H to F is stock, 19" H to F is UpCountry.
2004 WJ Laredo-selectrac 242-I6- Custom XJ intake w/Amsoil cone filter- PSC HD Pump & Res- PSC ported box- B&M trans cooler- B&M PS cooler- Custom chevy 1 Ton over the knuckle steering- Rough Stuff 1 Ton tierod & draglink ends- Saguaro 4x4 Front 3/4" shackles, Rear hitch & Warn 3/4" shackle-Mopar Front skid,Gastank skid -IRO TC skid- RRO super sliders- 6.5'' IRO critical path lift -IRO extended rear arms-Bilstein 5125 shocks -IRO F&R 6.5'' Bump stops-Carolina drive shaft-16x7 black soft 8's - 34'' Super swampers-Yukon 4.11 gears -Ultimate RCV shafts - LockRight Locked ECGS bolt in rear D60 -35 spline Chomloy shafts -BTF HD diff cover -IRO Adj A-arm-OX Locked super D30 -OX HD diff cover -OX drive away lock-Rock Krawler d30 truss-Stillen rotors & Matrix pads-JKS Adj Track Bar-JKS Quicker discos -Relocated OME SD-40 Steering Stabilizer-BDS stabilizer brackets-Relocated washer bottle-Removed rear sway bar-Cobra CB-TomTom one XL navi-alpine deck
Still to come: Flowmaster 50suv
Some of my videos:
Originally Posted by billyjp2 View Post
I burnout on puppies and kittens
Originally Posted by vwmaniacx View Post
Lets not and say we didn't.
WJ04 is offline
post #5 of 17 Old 08-05-2011, 05:17 PM
r_kelly252
i agree, upcountry.
check the classifieds and also check ebay.
rockauto.com is a GREAT place for those spring isolators and even sway bar bushings your looking for.
imho it would be very dumb to add spacers to spring isolators that are shot. replace them so once you decide that a budget boost is the direction you want, you would have already had you isolators done and will appreaciate it later.
Also for light duty trails 2" budget boost isnt all that big. you can also run oem length shocks on a budget boost theres one on the classifieds for $100 shipped.
r_kelly252 is offline
post #6 of 17 Old 08-05-2011, 07:26 PM
straty1987
i thought it was
stock front 18". rear 19"
upcountry 19" front. 20 rear
the wj front end is lower then the rear so numbers are not the same all around
straty1987 is offline
post #7 of 17 Old 08-05-2011, 09:52 PM
=KZ=
Originally Posted by straty1987 View Post
i thought it was
You know I have researched this a fair bit myself and the fronts I agree are front 18", 19" if upcountry. But rears I believe is very debatable some say the front rake is 3/4 inch (at least leveling kits are this height) and some say 1/2 inch and some say 1 inch. My springs with original isolators are 17 5/8 front 18 1/2 rear. 18 1/4 with a full tank of gas. Hard to find the definitive answer.
=KZ= is offline
post #8 of 17 Old 08-06-2011, 07:42 AM Thread Starter
cheezy
i'm not looking to lift right now, i just bought the wj and it has new tires. i'm just looking to return it to stock height. maybe i'll just leave it alone for now.
cheezy is offline
post #9 of 17 Old 08-06-2011, 11:04 AM
billzcat1
Chicken in a Turkey Suit
2003 WJ
If you are in there replacing springs, you might as well replace isolators as well. There's no point in putting new parts on top of worn out originals; you're not doing yourself any favors. My Jeep had Upcountry suspension which I took off when I lifted it. The original measurements showed that the collapsed isolators were responsible for 5/8" of sag and my sagging springs were responsible for 3/4" of sag.
On that note, I wouldn't recommend buying used Upcountry springs. It is highly likely that they are saggy just like your original springs. If you want to stay stock, that $125 set of Moog springs sounds like a great deal. Add about $100 for isolators from RockAuto and then the job will be done RIGHT.
~Richard
billzcat1 is offline
post #10 of 17 Old 08-06-2011, 12:22 PM Thread Starter
cheezy
this was what i was thinking about installing, or replacing the stock springs.
http://www.cyberjeep.com/wj/pr/coil-...ar-75-lift-red
cheezy is offline
post #11 of 17 Old 08-06-2011, 12:55 PM
billzcat1
2003 WJ
Those won't fit a WJ. WJs use different spring seats than the XJ/ZJ/TJ (which are all the same)
~Richard
post #12 of 17 Old 08-06-2011, 01:22 PM
r_kelly252
Agreed with ^^^^ bilzcat is right. $125 for new springs and $100 new isolators she'll ride nice again. like that luxury grand cherokee ride!
post #13 of 17 Old 08-06-2011, 02:36 PM Thread Starter
cheezy
i know what the description on the top said, but below it lists these. i'm confused?
Fits these vehicles:
  • 1984 Jeep Cherokee (XJ)
  • 1985 Jeep Cherokee (XJ)
  • 1986 Jeep Cherokee (XJ)
  • 1987 Jeep Cherokee (XJ)
  • 1987 Jeep Wrangler (YJ)
  • 1988 Jeep Cherokee (XJ)
  • 1988 Jeep Wrangler (YJ)
  • 1989 Jeep Cherokee (XJ)
  • 1989 Jeep Wrangler (YJ)
  • 1990 Jeep Cherokee (XJ)
  • 1990 Jeep Wrangler (YJ)
  • 1991 Jeep Cherokee (XJ)
  • 1991 Jeep Wrangler (YJ)
  • 1992 Jeep Cherokee (XJ)
  • 1992 Jeep Wrangler (YJ)
  • 1993 Jeep Cherokee (XJ)
  • 1993 Jeep Grand Cherokee (ZJ)
  • 1993 Jeep Wrangler (YJ)
  • 1994 Jeep Cherokee (XJ)
  • 1994 Jeep Grand Cherokee (ZJ)
  • 1994 Jeep Wrangler (YJ)
  • 1995 Jeep Cherokee (XJ)
  • 1995 Jeep Grand Cherokee (ZJ)
  • 1995 Jeep Wrangler (YJ)
  • 1996 Jeep Cherokee (XJ)
  • 1996 Jeep Grand Cherokee (ZJ)
  • 1997 Jeep Cherokee (XJ)
  • 1997 Jeep Grand Cherokee (ZJ)
  • 1997 Jeep Wrangler (TJ)
  • 1998 Jeep Cherokee (XJ)
  • 1998 Jeep Grand Cherokee (ZJ)
  • 1998 Jeep Wrangler (TJ)
  • 1999 Jeep Cherokee (XJ)
  • 1999 Jeep Grand Cherokee (WJ)
  • 1999 Jeep Wrangler (TJ)
  • 2000 Jeep Cherokee (XJ)
  • 2000 Jeep Grand Cherokee (WJ)
  • 2000 Jeep Wrangler (TJ)
  • 2001 Jeep Cherokee (XJ)
  • 2001 Jeep Grand Cherokee (WJ)
  • 2001 Jeep Wrangler (TJ)
  • 2002 Jeep Grand Cherokee (WJ)
  • 2002 Jeep Wrangler (TJ)
  • 2003 Jeep Grand Cherokee (WJ)
  • 2003 Jeep Wrangler (TJ)
  • 2004 Jeep Grand Cherokee (WJ)
  • 2004 Jeep Wrangler (TJ)
  • 2005 Jeep Grand Cherokee (WK)
  • 2005 Jeep Wrangler (TJ)
  • 2006 Jeep Grand Cherokee (WK)
  • 2006 Jeep Wrangler (TJ)
cheezy is offline
post #14 of 17 Old 08-06-2011, 05:22 PM
billzcat1
2003 WJ
They CAN'T fit both the TJ/ZJ/XJ configuration AND the WJ configuration AND the WK configuration. Those are three totally different applications. You could apply common sense, or you could buy them and waste $40. I'm just trying to help here.
~Richard
post #15 of 17 Old 08-06-2011, 06:10 PM
=KZ=
Why not just purchase from Kolak and then you will get good advice and customer service and the right stuff. Just do a member search and pm him.
=KZ= is offline
Rear Disc Brake Spring LubeckTech WJ Grand Cherokee Forum 1 06-30-2011 11:30 AM
Caliper Spring Question mswansonpcs WJ Grand Cherokee Forum 4 05-26-2011 09:42 PM
Rear caliper support spring: do I need them? jclaudii WJ Grand Cherokee Forum 2 03-18-2011 10:27 AM
two inch lift spring question cialert WJ Grand Cherokee Forum 0 11-19-2010 09:51 AM
lift kit spring question NoJeepHere WJ Grand Cherokee Forum 1 06-14-2004 09:35 PM
